Tub Suround Measurement - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-05-2009, 10:58 PM   #1
I'm interested in installing a prefab tub suround to replace the tile. But am not sure how to measure for the correct size. Do I measure from the finished walls above the tub, the finished alcove size, or do I use the actual tub dimensions?
rlblair is offline   Reply With Quote
Old 09-07-2009, 10:09 AM   #2
Remodeling Contractor
the surround will come in standard sizes with some flexibility. You measure the rough opening. So measure from the back wall to the tub edge add 1/2" for the drywall and 1/2" for the tile and thinset. Double this (add 2") for the length.
Old 09-07-2009, 08:09 PM   #3
Thanks Bob, have you had experience with this type of product? http://www.asbcorp.com/products3.asp?prod=44
Old 09-09-2009, 04:44 AM   #4
yes, these are easy to install. the corners overlap some to leave some flexibility with the quality of the walls. but the areas should be square and level for it to look good.
Vanity Top measurement HandyAl Remodeling 1 01-14-2008 08:13 PM
