Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-11-2011, 12:25 PM   #1
Question
Tub to Shower Drain Conversion
Due to a plumbing leak the tub and surround had to be removed. I have decided to ditch the tub and go with a shower instead but am not sure if I'm getting in over my head.
Details>>> Townhouse w/ concrete slab. Wall in bathroom is a common shared wall w/ neighbor. The plumbing is somewhat shared as well. It meets with neighbors then shares a drop (Like a T, I think. Terrible design). the drain is below the slab and it looks like i would need to be moved away from the wall slightly, not sure. Can someone please take a look and tell me what you think needs to be done? I don't want to accidentally do something that will adversely effect my neighbors plumbing. In the last 2 pictures my plumbing is to the left of the black pipe. I'd appreciate any input. Thank you!
Tub to Shower Drain Conversion-dsc00891.jpg   Tub to Shower Drain Conversion-dsc00894.jpg   Tub to Shower Drain Conversion-dsc00895.jpg   Tub to Shower Drain Conversion-dsc00916.jpg   Tub to Shower Drain Conversion-dsc00917.jpg
chris85016 is offline   Reply With Quote
Old 01-11-2011, 03:39 PM   #2
Stuck in the 70's
Blondesense's Avatar
I would suggest you ask a moderator to move your question over to the plumbing forum.
I think you will get more input over there.
The Following User Says Thank You to Blondesense For This Useful Post:
chris85016 (01-12-2011)
Old 01-12-2011, 09:54 PM   #3
Your first roadblock is that you need to replace the 1 1/2" tub drain with a 2" for a shower. Anything you alter can negatively impact your neighbor. At the very least, let them know what you are doing since it is shared plumbing.
If it were me, I would ditch the shower idea and just replace the tub with a new one.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
chris85016 (01-13-2011)
Old 01-12-2011, 10:37 PM   #4
Super Moderator
Rotten looking old plumbing you have there---The neighbor is already using a Fernco on a fitting--
My guess is the T is rusted to badly for more work without failing,
Dig around the T and see if you have a 2" drain under that T between the two tubs--
Jims right about 2" for a shower-
Need to know what the actual drain size is----Mike---
Please add your location to your profile--that helps in many ways--M--
oh'mike is online now   Reply With Quote
Old 01-13-2011, 10:40 PM   #5
Thanks for the advice.I appreciate it, only problem is, I didn't check earlier! Well, I replaced the p trap and moved the drain away from the wall. Hopefully everything is ok. I have another question regarding the cure time on the concrete I used to fill the hole in the slab......do I have to wait 5 days before I start doing the pre slope ?
Old 01-13-2011, 11:16 PM   #6
Super Moderator
No---You can get started as soon as the concrete is hard
This link might helpShower Construction Info (a collection of posts) - Ceramic Tile Advice Forums - John Bridge Ceramic Tile
Let us know how things are going.
Old 01-14-2011, 12:10 AM   #7
Thanks. I'm sure ill have more questions before I'm done
The Following User Says Thank You to chris85016 For This Useful Post:
oh'mike (01-14-2011)
Old 01-14-2011, 05:23 PM   #8
The existing drywall in the bathroom is 5/8" and the backer board that I am using is 1/2". What do I do? Do I have to replace the drywall (with 1/2") on the walls that meet up with the shower?
Old 01-14-2011, 05:39 PM   #9
Super Moderator
Two easy ways----If the old 2x4s are all warped and crooked--Sister nice new flat ones next to the existing ones--1/8 inch forward---
If the old studs are straight and flat (and where you want them--studs for mounting shower doors?)
Add 1/8 inch rippers to the face of the old ones--use a table saw if you have one.
It's a good idea to add some blocking to the back wall for a safety grab rail.
Old 01-14-2011, 05:43 PM   #10
Super Moderator
I looked at the picture---sistering in new studs will only take 8 studs or so--That's what I would do-
Nice to have a good stiff straight wall to start with.--Mike--
Tags
plumbing shower
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-22-2010 12:45 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Big Mistake with a basement shower drain lindq175 Plumbing 4 10-06-2009 03:11 PM
Solution for 1.25" drain pipe for removable shower? CZ DIY Plumbing 3 10-06-2009 11:20 AM
