-   -   tub backsplash delay time before last/first row? (http://www.diychatroom.com/f15/tub-backsplash-delay-time-before-last-first-row-126277/)
wraiththe 12-11-2011 12:32 PM
For this tub backsplash, I will be screwing three level strips to the wall and doing the tile above it, then comming back to custom fit the bottom (cutting about an 1/2 to 1" off each tile.) Does it matter how long I wait to restart that last row of tile? When I remove the strips and before I start the bottom row; I have to reseal the wall where the holes will be - and let it set before I start thinsetting the bottom row of tile.
I wonder if it is a bad idea to wait a day before applying the thinset to the bottom row?
The tub (Kohler-Archer model) is level, but the backside of the tub is not straight, but sort of complexly bowl/convex shaped on the back... I plan on making the gap consistently 1/8"
joecaption 12-11-2011 05:46 PM
You need to be starting this at the bottom and working up to the top not working your way down.
oh'mike 12-11-2011 05:56 PM
Joe--he nailed a ledger board one tile up---and is talking about setting the missing row---
What water proofing did you use?
Typically with a paint on ,like Red Guard or Hydroban--an hour or so is plenty of time--
Pull the ledgers--clean off any thinset that is in the way---touch up the little screw holes---
by the time you set up your wet saw and work station--mix a bucket of mud---the wall is dried enough to set--Mike---
wraiththe 12-11-2011 10:00 PM
1 Attachment(s)
The water proofing is the Wedi board itself. Then there is sealer over the fasteners and in the corners. Here is and experiment I made to show my girlfriend it was waterproof. I built a small water tank by using the sealer to glue several boards together and three hours later filled it with water. That was three days ago. Not a drop has leaked yet.:yes:
Bud Cline 12-11-2011 11:13 PM
Wait over night before removing the ledgers.
This is a continuation of another ongoing thread, why a new thread was started for this question is beyond me.
By the way wraiththe I looked at your other thread and the grout information as you requested and I don't see anything I would do different. All you have to do is to choose your grout product.
WeAreHandy 12-13-2011 05:42 PM
Guess he wanted to show his new fish tank
oh'mike 12-13-2011 06:56 PM
I saw a paper bag filled with water once---Hydroban---Good stuff.
