Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-11-2012, 12:20 PM   #1
Trying to decide how to do bathtub surround
We have a chipped bathtub and I've never been happy with the tile job around the tub, so I'm planning on tearing it all out starting over. I was pretty much set on 12" tile rather than a vinyl surround, but a friend's girlfriend (who owns a plumbing and remodeling business) said "I wouldn't." She's no longer in the picture and I never ended up asking why. Left to my own devices I'd probably still choose tile but I'd like to hear some thoughts.
We only have a single bathroom in the house so ideally I want to get this done in a weekend if possible, or it at least needs to remain usable at the end of each day. I've tiled a handful of floors and learned when I did this bathtub surround so I'm confident in my ability.
Vinyl surround pros:
- Built-in shelves
- Easier to not screw up
Vinyl surround cons:
- Doesn't go all the way to ceiling
- I'll need to do some drywall work and texturing
Tile pros:
- Can cover any area I want, up to ceiling
- Cheaper
Tile cons:
- No built-in shelves
- I'm afraid grout will be impossible to keep looking good with our hard water
The built in shelves thing is what has me a bit off. I see these things at Home Depot, which look great, but they're 8" which doesn't really jive with the 12" tile I would be using. Everywhere else I've seen them the cost is absolutely ridiculous (like $90+ apiece). I want built-in shelves but I don't know how to make that work.
qoncept is offline   Reply With Quote
Old 09-11-2012, 12:42 PM   #2
If the time it's unusable is your main concern then your stuck wil less options. A company like Bathfitters can come in and install a tub liner, and the enclosure in one day.
Going to cost far more but it can be done.
If you go with tile and a new tub there's just no way your going to be doing this over a weekend.
Even a new tub and nail up encloshure will take more then that for a DIY.
Old 09-11-2012, 12:52 PM   #3
Super Moderator
Demo tub and surround
Replace mixer valve
fix studs so wall is flat----day one
Durrock walls ---add waterproof coating---start tiling-----day two
Finish tiling---day three
Epoxy grout (nasty water won't stain that!) install trims---caulk---day four,
oh'mike is online now   Reply With Quote
garlicbreath (09-12-2012)
Old 09-11-2012, 01:12 PM   #4
If I can sit in the bathtub, that's a day that counts as okay. The plan is to do it while my wife is out of town so I could also baby wipe for a day. Here's what I see happening:
Thursday night: Tear out tile
Friday night: Take out and replace the tub
Long Saturday: Durrock and tile
Sunday: Grout
Maybe tiling takes through Sunday and I do the grout on Monday.
That's reasonable, isn't it? Mike, I'm not sure what you mean by fixing the studs. After I tear out the old, what is there to do other than putting up new durrock?
Old 09-11-2012, 01:18 PM   #5
angelatc's Avatar
My .02? I'm a female, and I hate hate hate tub enclosures. Tile is so much prettier, and it's easier to keep shiny and clean.
angelatc is offline   Reply With Quote
Old 09-11-2012, 07:00 PM   #6
Stuck in the 70's
Blondesense's Avatar
A couple of thoughts:
Tile is usually considered an upgrade.
When you compare costs, don't forget to include tools and supplies. Unless you have a good buddy with a tile saw, float, trowels, sponges,etc., by the time you add it all up you may not be saving much.
Doing an enclosure will be infinitely faster, especially if you don't have tiling experience. A good tiling job takes time planning. If you start in a corner and just start slapping it up, it will look like a newbie job.
Lastly, and very important. If you manage to do this in four days, you will be tired, and thinking "Oh, I'll just finish cleaning this grout haze off tomorrow." DON"T DO IT! Don't go to bed until the haze is as gone as you're gonna want it cuz odds are it won't come off the next day.
The Following 3 Users Say Thank You to Blondesense For This Useful Post:
garlicbreath (09-12-2012), mae-ling (11-17-2012), oh'mike (09-11-2012)
Old 11-17-2012, 03:45 PM   #7
I do not understand how tile can be less expensive than 5 panel glue in tub surround.
They can be ordered 80 inches tall and can be had for$200 here in Ontario Canada, I am sure they are even cheaper in the U.S. I plan to use a glue in over blue drywall to lower cost.
arnoldander is offline   Reply With Quote
Old 11-17-2012, 05:30 PM   #8
Do the tile...will look better and better for resale later on
toastandjam is offline   Reply With Quote
Old 11-28-2012, 10:36 AM   #9
Well, I don't have the receipts but I did it for about $200. ~60 tiles at $1.50 apiece was the biggest cost.
Now, I bought these porcelain shelves to put in the corners that I haven't dealt with yet. I need to cut the porcelain tile 1 1/2" x 4 1/2" but I have no idea what the best way is going to be. I have a diamond cutoff wheel for the rotary that worked great for pass thru holes that were going to be covered with shrouds, but the flange on these shelves is only 1/4". I need to have square corners and little margin for error.
Any advice? My best guess at this point is to make the long parts of the cuts with that diamond cutoff wheel, then use an oscillating tool in the corners.
Old 11-28-2012, 11:59 AM   #10
Stuck in the 70's
Sounds like these shelves should have been installed as the tile was going up, and the cuts on the wall tiles done before installation.
I don't know what you want to do is possible, but I'd be real hesitant to risk my new tile job.
In your shoes I might look for a plan B. Maybe you can find a shelf you like that is flat to the wall using silicone adhesive.
Old 11-28-2012, 12:14 PM   #11
I think that's probably the way to go. These stupid flanged shelves make absolutely no sense. They want you to epoxy it in place anyway, why wouldn't it just be a surface mount? And there are very, very few options for a surface mount shelf. Ugh.
Old 11-29-2012, 10:59 AM   #12
Stuck in the 70's
Ebay has some.
http://www.ebay.com/itm/Marble-Trave...item3f1d4e7f87
If you have an Ikea store nearby, you might check out these:
http://www.ikea.com/us/en/catalog/products/50072645/
http://www.ikea.com/us/en/catalog/products/90072648/
I bought the pair and installed them with silicone. I really like them. The basket is great for small bottles, razors etc. Then add S hooks for bath poofs or anything that can be hung up. Saves limited shelf space for the big bottles.
Question on Bathtub surround and floor Tile Install veesmack323 Flooring 15 02-27-2012 04:01 PM
Ceramic Tile around a Surround Bathtub that has been cut LittleRascals Flooring 1 10-03-2011 01:12 PM
Bathtub surround - quarter round? jarleifvaagen Remodeling 1 08-26-2010 10:16 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
