Trouble Locking Recessed Light In Place - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 01:24 PM   #1
Rewards Points: 127
Trouble Locking Recessed Light in Place
I am installing a recessed light in an a ceiling that has no access to the attic, so I am using an air tight Halo 5" IC remodel light. I am trying to get the clips to lock in place but am having a very difficult time. I got two to lock in place but the other two clips just won't snap into place. The clips are not hitting anything in the ceiling. Are there any tips or tricks to get these clips to snap into place? Ceiling thickness is 1/2 inch.
Thanks!
wkumtrider is offline   Reply With Quote
Old 05-01-2011, 05:31 PM   #2
Clip fix
Those suckers can be hard sometimes. I use a flat head screw driver and tap them up. Some times they need a little man handling. Just don't hit them to hard or you will break them. I have had some that broke before, and I had to replace the can. Ps: I've installed hundreds of them. Hope this helps.
Stanchek is offline   Reply With Quote
Old 05-01-2011, 09:24 PM   #3
DIY staff
Rewards Points: 7,174
I second that---stinking design---It's not you!
Old 05-01-2011, 10:53 PM   #4
Rewards Points: 5,336
There could be a few issues that are causing the problem.
The ceiling could be too thick or debris could be in the way.
The clips could be hitting framing.
The clips could be bent too much. Remove them and flatten them out a bit and re-install them.
Ron
Help; Suggestions for recessed shower light pdexter46 Electrical 1 03-31-2011 12:11 PM
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 09:27 PM
Recessed light directly over shower adpanko Electrical 33 09-16-2009 07:56 AM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 10:25 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
