Trimming A Marble Vanity Top - Foolhardy Or Worth The Risk? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 11:33 AM   #1
Trimming a Marble Vanity Top - foolhardy or worth the risk?
Newbie post here, and need a little advice....
I've recently embarked on a guest bathroom redo....and because of my long suffering OH not thinking there was anything wrong with builder basic I've agreed to do it for a very small......I mean small budget...but i have campagne taste.
So with the budget in mind, I've managed to score myself a marble vanity top for $100.... an absolute steal.......it's a 49"x 22" for a 48" cabinet.
Now, I took out a 60" cabinet because I felt it was just too big for the space, which is about 10' x 5' floor space (and not including the bath).
so my dilemma is .....do I keep it 49 inches or do I trim it down? Just how easy is it?... I plan to build the cabinet myself so the dimensions dont' have to fit a factory made base....and to make it a little more "fun" would have to take the same amount off both ends as the sink is centered....and it like it like that......
Thoughts? Concerns?
Cheers
bilbos92 is offline   Reply With Quote
Old 06-26-2012, 11:36 AM   #2
Just so I understand. Is the sink on the new marble top centered or??
CopperClad is offline   Reply With Quote
Old 06-26-2012, 12:24 PM   #3
Hi .....
At the moment the sink is in the center and fitted ( its an undermount ) ......if I want to keep it that way, which I do,.... I'll have to make two cuts, one each end. Obviously increasing my risk of making a mistake and as the sink is already glued in will have to do it with that attached........
My thought was to take it down to a 40 inch top, therefore taking 4.5 inches of each end....
Is it going to make that much difference in my risk/benefit analysis?
Old 06-26-2012, 12:33 PM   #4
I'm sorry. I'm just not following. If you are custom building your own cabinet.. Why do you need to cut the top at all?
Old 06-26-2012, 12:38 PM   #5
Rewards Points: 268
You can cut the top, but why bother? I would only cut it if you absolutely need that extra 9". Once you cut it you will have a sharp edge that you will have to address.
packer_rich is offline   Reply With Quote
The Following User Says Thank You to packer_rich For This Useful Post:
CopperClad (06-26-2012)
Old 06-26-2012, 12:48 PM   #6
Thanks......that really was what i needed...
I don't need to cut it...I think I was just overthinking the "visual" space issue...... that 40 inch "looked" better than 49 in my mind...
Looks like a 48 Inch cabinet is in my future......Thanks guys.......
I'm not really a ditherer.....honestly...
Old 06-27-2012, 10:58 AM   #7
EMD360's Avatar
I wouldn't cut it for 49" where you had 60". I have cut granite and the edge is hard to polish. I bought diamond sand paper in about 12 grits and used it from coarse to fine. The look is OK but not as nice as a factory finished edge. 48" is a nicer finished size too--good to have space around the sink.
EMD360 is offline   Reply With Quote
Trimming/sanding cultured marble - bathroom vanity top SpookyLugBolt Kitchen & Bath Remodeling 3 02-02-2010 09:24 PM
Marble vanity top Harvey Flooring 1 07-30-2009 04:34 PM
Bathroom Marble Vanity Sinks Vic&fred Remodeling 1 10-16-2008 02:47 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
