Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-10-2012, 09:42 AM   #1
Trim on Stairs
Just looking for opinions on how other would finish the spot pictured below where the stairs and the drywall meet. I am going to be putting hardwood down, with two pieces on the risers. A reducer will be cut to vertically finish the open end of the riser. I just wondering if putting a thin piece of trim over every vertical reducer and the drywall is going to look funny.
Does anyone have any other ideas/photos of how they have done this? (I do still have to remove the nosing)
Brett2311 is offline   Reply With Quote
Old 01-10-2012, 10:05 AM   #2
Trim on Stairs
I'm confused, nothing new about that, is the plan to remove the the OSB risers you have now?
If not it may throw off your tread and riser heights.
Why would use use 2 pieces of hard wood for the risers and not just one soild piece. With two there's a chance the gap may open up.
Did I read your post wrong, your planing on using hardwood flooring to make the treads?
Why not laminated hard wood treads? Trying to use narrow pieces of flooring will not work out.
Old 01-10-2012, 11:35 AM   #3
Trim on Stairs
I think my first message was confusing, I have all the proper pre made pieces for the tread and riser. My question is more about where the hardwood will meet drywall on the open end of the riser, whats the best way to make this look good, is it just trim to cover the unfinished look or is there a better way?
Old 01-10-2012, 12:42 PM   #4
Trim on Stairs
Most often you just make a skirt. http://www.staircraft.com/Skirts%20and%20Risers.htm
how do i trim my stairs?? dewcraw Carpentry 2 01-11-2010 03:53 PM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 05:01 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
baseboard trim gaps on stairs beppygirl General Discussion 8 02-24-2008 02:31 PM
Transitioning painted stairs to hallway and trim...HELP naromli Painting 2 01-26-2008 02:21 PM
