Trim & Molding Meet At 90 Degree Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 06:12 PM   #1
Trim & Molding Meet at 90 degree wall
Hi,
Quick molding question...
I have 2 doors on different walls which are at 90 degrees to each other. Both doors are fairly close to the same corner and will not be able to accomodate a full piece of trim on the sides that meet in the corner. The question is - Should I:
[a] install a full width piece of trim on one door and rip the other piece of trim to fit in the remaining space
[b] cut both pieces along the full length at a 45 degree angle so they form a right angle and meet flush
Thanks guys,
cyager01 is offline   Reply With Quote
Old 09-29-2012, 06:28 PM   #2
Rewards Points: 2,212
What type of trim? Profile or flat?
Are the doors equal distance from the corner?
If you put one in full and rip the other will it sit flush or is it up against a profile?
Painted grade or stained?
mae-ling is offline   Reply With Quote
Old 09-29-2012, 07:32 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
a photo may help in getting useful responses
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-29-2012, 07:51 PM   #4
DIY staff
Rewards Points: 7,174
Typically,I will miter that type of corner.
Better hope the doors are installed with the tops at the same heights.
BigJim (09-29-2012)
Old 09-30-2012, 08:35 AM   #5
Rewards Points: 512
i would put a full piece of trim on the one that will be seen more( like the one at the end of the hallway) and rip the less seen less noticeable one.
princelake is offline   Reply With Quote
Old 09-30-2012, 08:49 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by cyager01 View Post
Hi,
Thanks guys,
No matter if you 45 the backside or do not, the trim will still meet together at the same spot on the front edge so you could put in one piece and then rip and butt the next to it and then calk and paint...
hand drive is offline   Reply With Quote
Old 09-30-2012, 10:00 AM   #7
If it is painted trim.
Tags
molding , trim
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Matching crown molding and other trim tesierowe Interior Decorating 0 01-30-2011 06:06 PM
Trim and Molding Questions tdeepness Carpentry 2 04-29-2010 06:22 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 09:28 PM
