-   -   Trim & Molding Meet at 90 degree wall (http://www.diychatroom.com/f15/trim-molding-meet-90-degree-wall-158408/)
cyager01 09-29-2012 06:12 PM
Hi,
Quick molding question...
I have 2 doors on different walls which are at 90 degrees to each other. Both doors are fairly close to the same corner and will not be able to accomodate a full piece of trim on the sides that meet in the corner. The question is - Should I:
[a] install a full width piece of trim on one door and rip the other piece of trim to fit in the remaining space
[b] cut both pieces along the full length at a 45 degree angle so they form a right angle and meet flush
Thanks guys,
mae-ling 09-29-2012 06:28 PM
What type of trim? Profile or flat?
Are the doors equal distance from the corner?
If you put one in full and rip the other will it sit flush or is it up against a profile?
Painted grade or stained?
GBrackins 09-29-2012 07:32 PM
a photo may help in getting useful responses
oh'mike 09-29-2012 07:51 PM
Typically,I will miter that type of corner.
Better hope the doors are installed with the tops at the same heights.
princelake 09-30-2012 08:35 AM
i would put a full piece of trim on the one that will be seen more( like the one at the end of the hallway) and rip the less seen less noticeable one.
hand drive 09-30-2012 08:49 AM
Originally Posted by cyager01 (Post 1020143)
Hi,
Thanks guys,
No matter if you 45 the backside or do not, the trim will still meet together at the same spot on the front edge so you could put in one piece and then rip and butt the next to it and then calk and paint...
mae-ling 09-30-2012 10:00 AM
If it is painted trim.
