Tricks To Laying Out Baseboards? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-05-2009, 06:52 AM   #1
DIY Expert in Training!
Tricks to laying out baseboards?
I am getting ready to put in trim. The room isn't level. How do I lay out the baseboards? Find the highest and lowest points and decide on a level to start from?
Thanks!
gone_fishing is offline   Reply With Quote
Old 04-05-2009, 07:18 AM   #2
Now far out of level?? If you set the baseboards level, everything will look out of whack. Make the baseboards conform to the house.
Old 04-05-2009, 01:12 PM   #3
Drywall contractor
Rewards Points: 1,070
The base has some "give" to it so you can "adjust" (to some extent) to compensate. Use "gauge blocks" (scrap pieces of wood) to set your base on at the height you want to set it off of the floor (generally 3/8" - 1/2"). Start nailing in the corner and work your way down the piece pushing it down where it's sitting high and prying it up where it's low. As Bill said, it won't look right if it's not a (fairly) uniform height off of the floor. If you're carpeting, the carpet won't "tuck" under the base if there's not enough space....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-05-2009, 01:15 PM   #4
Remodeling Contractor
You still follow the floor. If the corners are bad, you may have to cut at compound angles to handle the vertical angle incurred from one floor out of level and the other not. 3 dimensional trim..oh what fun.
Old 04-05-2009, 04:44 PM   #5
Rewards Points: 5,336
Thanks!
What you do will depend on the type of finished floor you will have. If you have a carpet, you can fudge a bit and raise the molding off the floor a bit to make the corners a little easier. If you have hardwood, I'd recommend a two part base system. The base molding and then a shoe molding or something similar to take up the gaps that will surely appear under the main molding.
Ron
How Best to Paint Baseboards in Carpeted Rooms? biggles99 Painting 22 04-17-2011 06:44 AM
Cutting Baseboards on the Wall?? chefwillymac Carpentry 9 09-18-2008 07:40 AM
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
