Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-17-2012, 10:33 AM   #1
Trex and Building Codes
I am about to put a framers porch on my house, and want to use trex decking, does anyone know if the floor joist have to be 12" when using trex decking?
Jamie O'Leary is offline   Reply With Quote
Old 04-17-2012, 10:37 AM   #2
Only if you install on an angle, 16" if it's at right angles to the joist.
Old 04-17-2012, 08:56 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
as joe said, if your running the boards on the angle it creates a longer span so the joists have to be closer together.
keep in mind that composite decking will flex and sag in the summer months as it warms up
woodworkbykirk is offline   Reply With Quote
Old 04-17-2012, 09:28 PM   #4
Moderator
kwikfishron's Avatar
There are "many" better options than Trex.
TREX decking extremely disappointing
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 04-17-2012, 09:48 PM   #5
Stairguy
Yes it's called "wood"
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
kwikfishron (04-18-2012)
Old 04-19-2012, 07:07 PM   #6
Stainless Cable & Railing
Trex decking with cable railing holds up pretty well in the WET Northwest. Its not as bad as most people say, but you can get a bad batch [Trex decking]. Got a nice list of Trex Decking projects with different cable railing styles on Youtube. See it here: Trex Decking
Leave a comment tell me what you think. Made the video myself...
cablerailing is offline   Reply With Quote
Old 04-19-2012, 09:49 PM   #7
Moderator
Nice.. you better check code.
Done miles of Cable Rail and 3" spacing (on cable) is code here (100 miles away from you).
I'll play nice and bite my tongue on any more exterior composite comments.
-NEW MEMBERS-
TREX decking extremely disappointing KHL General Discussion 263 08-30-2012 01:18 PM
Cheapest building materials TREX and Hardie Plank Dr.JUSC Building & Construction 0 08-12-2011 12:51 PM
Trex Deck samarama Building & Construction 2 07-11-2011 03:21 PM
Cutting Trex Transcend rsmith0399 Building & Construction 7 09-04-2010 09:53 PM
Trex Decking & Railing Systems Patricia Folsom Building & Construction 11 10-08-2008 10:06 PM
