No, you don't "have" to use p.t.(for the last 37 years, maybe longer)- there are other woods available for slabs, #3:
http://publicecodes.citation.com/ico...9_3_sec017.htm
"Naturally durable wood":
http://publicecodes.citation.com/ico...9_2_sec002.htm
Notice- it has to be "heartwood", not sapwood:
http://www.wrcla.org/cedar_benefits/...cteristics.htm
Even with a sill-sealer under
other wood (not decay durable), it may not pass. Check locally. If recent construction, poly is required per Codes under a slab, but you would have to
prove that it is present to the Inspector when using standard wood plates on concrete.....
The sill sealer is for a capillary/thermal break to the cold concrete touching earth unless it had a foamboard layer per location when the slab was pored.
http://www.greenbuildingadvisor.com/...-building-code
Gary
P.S. Welcome to the forums!
Clothes taking longer to dry?
