Tray Ceiling Beams - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-15-2009, 07:40 PM   #1
Tray Ceiling Beams
I am planning to construct 2 12 x 12 inch beams to go accross our tray ceiling in kitchen and then rehang the ceiling fan and install 4 recessed lights in the 4 squares of the ceiling.
Just looking for and tips...I am planing on framing the beams and covering with sheet rock to mach up to the existing ceiling which have a smooth finnish.
I have alot of electrical experience but not too much on the framing side or sheetrock work.
jsetchen is offline   Reply With Quote
Old 01-16-2009, 07:14 AM   #2
SNC
Are you talking about a coffered ceiling? Why the 2x12s ? All you need (if it just decorative) is 1x4.
http://www.onlinetips.org/design-coffered-ceilings
I really like these, I just did this in my dinning room, make it a real eye opener when you walk in.
http://www.taunton.com/finehomebuild...-ceilings.aspx
http://homebuilding.thefuntimesguide...cture_idea.php
SNC is offline   Reply With Quote
Old 01-16-2009, 11:18 AM   #3
Ceiling Beams
What I am actually trying to do is a cross beam system dividing the already trayed ceiling into 4 sections after making the beams. Each beam being 12 inches deep to match the depth of the tray and crossing in the middle. Beams would also be 12 inches wide giving me the width to remount a ceiling fan....Plan to install recessed lighting in each of the 4 squares.
Old 01-16-2009, 12:22 PM   #4
Rewards Points: 26
You will have to find out which way your trusses run. The beam that will run perpendicular to your trusses you will be able to nail/screw right to the trusses but the beam running parallel to your trusses you will probably need to add some nailer's in between the trusses to attach the beam to. Other than that it is pretty straight forward.
If it was me I would attach a 2x10" to the trusses with lag bolts. Then I would use 5/8" plywood for the sides, easy to cut and screw to the 2x10 on the ceiling. Cut a couple of square blocks the size of the opening so the plywood doesn't twist and nail them in. Then cut 2x4s-9 1/2" long and nail them in on the bottom of the plywood every 16" to create the framing for the drywall on the bottom. Then drywall everything and finish. This will give you an 11 1/2" wide beam.
ponch37300 is offline   Reply With Quote
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
ceiling tray down from 8' ceiling rtoni Building & Construction 8 08-15-2008 03:07 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
New ceiling for uneven beams RogCat Remodeling 4 01-14-2008 05:47 AM
