Top Plate Interior Wall Remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 06:51 PM   #1
Rewards Points: 892
Top plate interior wall remodel
I can't find what I'm looking for online.
I'm adding two interior partition walls that will join at a corner.
How to I attach the top plate to both if the ceiling drywall is already in place?
How would I frame the corner on this remodel?
Daugela is offline   Reply With Quote
Old 07-05-2013, 07:01 PM   #2
DIY staff
Rewards Points: 7,174
This is a partition--can you stand up walls or must they be built in place?
Can you nail into ceiling joists or will you need to add blocking?
Old 07-05-2013, 07:06 PM   #3
Rewards Points: 892
I could raise up but it would be tight since the bottom plate would be accommodating my bathroom plumbing. I would rather build in place.
I can attach top plate to joists. One wall will be perpendicular to trusses. The other wall is already in place. I'm essentially moving an interior wall.
How do I tie to the other wall near the top plate? The other wall in place has a top plate which was used in the wall that I just demo'ed.
Old 07-05-2013, 07:10 PM   #4
Rewards Points: 892
You can see where I placed the bottom plate down.
Old 07-05-2013, 07:15 PM   #5
DIY staff
I would attach the floor plates first---then cut studs for both ends of the wall---cut the top plate---and use the studs to hold up the top plate--get the studs plumb and nail in the top plate---
There are several ways to frame a corner---the L- corner is simplest--cut two studs the same length (for the corner) lay them on the floor--one flat and the uther on edge---nail them together along the length.
orient them so that the one with the nail heads is at the end of the wall--and the other is facing the direction of the joining wall---
Old 07-05-2013, 07:23 PM   #6
DIY staff
You do not have a wall corner--you have a wall intersection---that takes 3 studs--
Cut to length---lay one flat on the floor--and the other two on edge along either side of the flat one--nail together--- that is the wall intersection and is placed into the existing wall where the new wall will attach.flat stud facing the new wall--
Old 07-05-2013, 07:35 PM   #7
Rewards Points: 892
So no intersecting double top plate? The L corner will tie in?
Old 07-05-2013, 07:41 PM   #8
DIY staff
No real need for a double top plate on a partition---
Old 07-05-2013, 07:41 PM   #9
Rewards Points: 892
You can see I need to trim back the existing wall and make shorter to the new bottom plate.
Old 07-05-2013, 08:00 PM   #10
DIY staff
It looks like you have some wires to sort out---but the framing looks fairly straight forward.
What is the nailer for that runs horizontally about eye level?
Old 07-05-2013, 08:13 PM   #11
Rewards Points: 892
It went to nothing. No clue why they put that there. The studs are notched out to accommodate them. Figured I'd leave them but will be putting in a door on the far right side. Is there a standard how far a door should be framed from an existing wall?
Old 07-06-2013, 04:40 AM   #12
DIY staff
You need room for trim---I usually try for 3 studs---4 1/2"-- but two studs 3" will work if you are using a thin trim.
Old 07-06-2013, 09:25 AM   #13
AHH, SPANS!!!
Rewards Points: 1,166
when adding additions, to pass code we always add L angle braces in the corners to connect new walls to old walls at the plates. add the angles both sides of wall. for the other side of room where new wall butts drywall you can notch out the drywall to accommodate the new wall. with doing this you may (most likely)need to add blocking in the existing wall to catch old drywall on both sides of new wall and to attach new wall to. you might encounter obstacles in old wall that prohibit the new wall with blocking to notch in, could just put wall stud against drywall and nail/screw where there is solid connection in wall- bottom, top plate etc...
hand drive is offline   Reply With Quote
Old 07-06-2013, 09:16 PM   #14
Rewards Points: 892
So are you saying 3 studs and then my jack stud or is the jack stud considered 1 of 3?
I'm thinking 2 studs plus the jack to equal 3 total studs. No?
Old 07-07-2013, 03:29 AM   #15
DIY staff
Two studs and the jack---
Rotted sole plate in bathroom firemanter Carpentry 3 05-30-2013 02:14 PM
Framing - How should I attach top plate? NEW-B Building & Construction 1 01-13-2011 08:13 AM
No top plate overlap at interection Tony-B General DIY Discussions 3 08-02-2010 08:52 PM
Top plate over header? zenman Building & Construction 6 08-05-2009 12:04 PM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-22-2006 11:01 PM
