Tongue And Groove Ceiling Install....questions... - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2007, 08:28 AM   #1
Tongue and Groove Ceiling install....questions...
Greetings,
Just purchased a home in the woods,...and in a remodeling plan to give it more of a rustic look we are looking into either exposing the beams in the kitchen foyer ceiling OR doing tongue and groove on it. This ceiling is under the 2nd floor. There would be no structual walls or features affected.
Question: If I rip all the drywall out to see what kind of shape the beams are in, and then decide to do tongue and groove can I just do the T&G onto the beams? (assuming they run in the proper direction) OR would I need to re-drywall and then install?
thx!
Dr. Jim is offline   Reply With Quote
Old 07-17-2007, 09:46 AM   #2
Rewards Points: 768
I finished our attic a couple months ago and ran carsiding (aka tongue and groove pine) right over the ceiling joists. As long as your beams are in line and won't make the finished ceiling wavy I would just go over them. Make sure you have insulation there before doing that.
cibula11 is offline   Reply With Quote
Old 07-17-2007, 12:39 PM   #3
Rewards Points: 5,336
The beams will be 2x8's or 10's. There will be wires running through them, maybe plumbing. There will be nails sticking out of the floor above.
You should be able to see which way the joists are running without removing the ceiling. You don't mention the thickness of the T&G wood. If 3/4", you can go directly on the joist. If it's 1/4-5/16" I would install it over drywall. You also don't mention the method of installation or whether it's finished or unfinished.
Ron
Old 04-04-2012, 07:09 PM   #4
Smile
tongue and groove wall
Originally Posted by Dr. Jim View Post
Greetings,
thx!
If you decide to t & g, you will not need to dry wall first, but remember that
dry wall is 1/4" thick and your t & g is 3/4" thick which means you will need
to adjust any light switches and electric plugs out 1/4" or check with Hardware store on extensions.
lynn Corum is offline   Reply With Quote
Old 04-06-2012, 03:28 PM   #5
Drywall contractor
Rewards Points: 1,070
Drywall SHOULD be 1/2" or possibly 5/8". Longer screws should solve any problem with light fixtures, or you can add and extension "ring" to the boxes.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 10:30 PM   #6
firehawkmph's Avatar
Rewards Points: 1,822
Dr. Jim,
Here's a few pics of a room I just did for a customer. Gutted the old paneling and acoustical ceiling. Tore out all the old attrocious wiring and rewired to code. Used t & g 1 x 8" pine. Fun to work with and came out nice. Also, here's a pic of my garage addition with the same pine going on the ceiling.
Mike Hawkins
Tongue and Groove Ceiling install....questions...-img_20120326_165728.jpg   Tongue and Groove Ceiling install....questions...-img_20120326_165755.jpg   Tongue and Groove Ceiling install....questions...-img_20120317_150639.jpg   Tongue and Groove Ceiling install....questions...-img_20120317_182730.jpg
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Tom Struble (04-07-2012)
Old 04-07-2012, 08:24 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
some inspectors want to see drywall with the seams taped behind wood paneling
Tom Struble is offline   Reply With Quote
Old 04-07-2012, 08:25 PM   #8
nice job there Mike
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
firehawkmph (04-07-2012), kwikfishron (04-07-2012)
Old 04-08-2012, 12:07 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
I think Dr Jim must be finished with his project by now, that thread was started in 2007. I have responded to a thread that was out dated also.
You did a fantastic job with the T&G, it looks great.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-08-2012, 01:14 PM   #10
LOL Jim,
I always forget to check the dates, even on milk cartons. Thanks,
Mike Hawkins
Tongue and groove miami vice 25 Flooring 8 04-04-2012 07:35 PM
Lighting tip needed for vaulted ceiling wease Electrical 5 02-25-2007 12:49 AM
