Tiling A Slanted Wall Around A Tub - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 05:09 PM   #1
Tiling a slanted wall around a tub
I am remodeling a bathroom in a townhouse I just purchased and because of the line of the roof, the wall to the left slants (like /). Because of this, when the tile is placed on the wall it does not turn out to be level with the tile placement on the back wall. How do I make this work? Do the grout lines on this wall just need to be a little bit thicker to make up the difference?
kadacd is offline   Reply With Quote
Old 01-12-2011, 02:44 PM   #2
Rewards Points: 5,336
No, you don't spread out the tiles. You just tile the slant as you would the wall and live with the issue.
Ron
Old 01-12-2011, 02:55 PM   #3
Experienced
Jackofall1's Avatar
How much gap are you talking about.
Is this something by which tiles need to be cut and fitted. You may have to start at that point cutting tiles to match the angle, you don't want to have to cut slivers thats for sure.
You really shouldn't grout corners in a shower, unless you are using a siliconized grout.
Old 01-12-2011, 04:32 PM   #4
The tiles on the slanted ceiling are going across the wall tile diagonally. There is no spacing scenario where the grout lines match up.
Ron
Tiling a shower wall cm3putter Building & Construction 1 11-23-2009 03:32 PM
What kind of wall for tiling bathroom and shower ghostdog Remodeling 1 03-26-2009 06:17 AM
Tiling a shower enclosure - questions re: hardiebacker & wall prep DyerWolf General DIY Discussions 10 01-15-2009 12:10 PM
Wall tiling trowl size help please. Hobb3s Remodeling 5 05-30-2008 08:45 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
