I am remodeling a bathroom in a townhouse I just purchased and because of the line of the roof, the wall to the left slants (like /). Because of this, when the tile is placed on the wall it does not turn out to be level with the tile placement on the back wall. How do I make this work? Do the grout lines on this wall just need to be a little bit thicker to make up the difference?
Is this something by which tiles need to be cut and fitted. You may have to start at that point cutting tiles to match the angle, you don't want to have to cut slivers thats for sure.
You really shouldn't grout corners in a shower, unless you are using a siliconized grout.
The tiles on the slanted ceiling are going across the wall tile diagonally. There is no spacing scenario where the grout lines match up.
Ron
Related Threads
DIY Home Improvement Forum
3.1M posts
320.1K members
Since 2003
