Tiling Shower With No Quarter Round - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-14-2007, 08:05 PM   #1
Tiling shower with no quarter round
I will be tiling a new shower and have found a tile that we like. The only problem is that there is no matching quarter round. How should I finish off the edges, where the tile meets the wall?
digexpressions is offline   Reply With Quote
Old 12-15-2007, 06:42 AM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
If the tile base matiral is the same color as the face you can just grout the edge, its not prefered but works. How about a bull nose from a different color as an accent?
Kingfisher is offline   Reply With Quote
Old 12-22-2007, 09:45 PM   #3
remodeling pro
Tile manufacturers who do not make trim pieces should be tied to a stake in the town park and subject to public beatings.
If your field tile is a blend, I would try to find a bull nose that is close enough to one of the colors, and use it as an accent, like Kingfisher suggested. If not you will just have to caulk the edge of the tile to the wall. Get a tube of color matched caulk from the tile supplier for this, so it will match the grout color. If you are using natural stone tiles like granite, marble, or limestone, and have a stone fabrication shop in the area, you could ask them how much they would charge you to bullnose the edges of some tiles for you, but don't expect any bargain prices.
troubleseeker is offline   Reply With Quote
Old 12-28-2007, 04:33 PM   #4
If the edge will be outside the shower door (where it won't get wet), you also could use a wood trim.
If you grout the edge, consider putting on the tile about an 1/8 inch shy and then grout with a 45 deg
HIDean is offline   Reply With Quote
Old 01-01-2008, 05:38 PM   #5
Insert catchy title here
AppleMac*Fit's Avatar
I know for using slate, and unfinished edge looks nice.
AppleMac*Fit is offline   Reply With Quote
Old 10-12-2008, 03:27 PM   #6
I just tiled a shower with porcelain tile that extends outside shower doors and above shower head. I am trimming it out with 1" wood trim that I have stained and sealed with semi-gloss spray poly. Cut all corners at 45 and ran a bead of colored caulk between the wood and tile.
pattyg2 is offline   Reply With Quote
Old 11-02-2008, 02:39 PM   #7
Rewards Points: 5,336
They have metal and plastic edging for this application. The metal comes in various thicknesses and finishes. Tile stores and the big box stores carry it.
Ron
small quarter round moulding mf915 Flooring 11 09-30-2009 12:14 AM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 06:08 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 07:39 PM
Shower tiling website sharisavage Flooring 1 06-22-2005 08:14 PM
