Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-03-2011, 04:42 PM   #1
Tiling over tile
We are in the process of finishing up our kitchen remodel and want to tackle the backsplash. It is currently already tiled with newer tile but not what we are wanting. I am looking at some glass mosaic. Is it possible to tile over the existing tile as long as it is in good shape? I know it would probably be best to just start from scratch but we already have the counters and new sink and faucet installed... Any help would be great!
mkerns12 is offline   Reply With Quote
Old 10-03-2011, 05:30 PM   #2
Tileguy
Bud Cline's Avatar
Tiling over tile
Glass tile is problematic to begin with, I don't think I would install glass tile over existing tile. What about the edges? Will the edges be exposed if you do that?
So you want a path-of-least-resistance procedure?
Old 10-04-2011, 06:02 AM   #3
Tiling over tile
I will put some metal edge pieces on the ends.. I am for sure looking for the path of least resistance!!!
Old 10-04-2011, 07:10 AM   #4
Super Moderator
Tiling over tile
Is the existing tile flawless?
If it is then tile can be installed over the top using unmodified thinset mixed with liquid latex.
Kerabond and Keralastic is a good example ---Scuff the tiles before you start.
Contact the glass tile manufacturer -----glass is seldom used in a high traffic area like a kitchen because scratches will occur.
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 04:17 AM
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 06:49 PM
