Tiling Outside Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 09:04 AM   #1
Tiling outside wall
My question is for design purposes really. I'm debating about whether or not to butt the tile all the way to the wall with no grout line vs. grouting the joint where the tile connects to the drywall. There won't be a groutline on the left side of the tile, so I didn't want it to look awkward for grout only on that one side. Any suggestions?
knighton is offline   Reply With Quote
Old 11-18-2009, 09:20 AM   #2
Remodeling Contractor
you would not grout a joint between tile and drywall anyway. You would caulk it. If the tile is ending as it appears to be in this picture then you use bullnose edges for the end run.
Old 11-18-2009, 09:31 AM   #3
Bob -
Thanks for the reply. I'm aware about caulking at junctures in tile vs. using grout. The meat of my question is should I run the tile all the way to the wall without grout caulking (making the appearance that the tile flows into the drywall) or do I leave a space for grout colored caulk?
Thanks.
Old 11-18-2009, 09:50 AM   #4
if you are talking about the right hand edge of your picture, the problem becomes that this tile edge has an unfinished edge that will not look good left as is. Use edging tiles or leave it short and caulk it.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Tiling a shower enclosure - questions re: hardiebacker & wall prep DyerWolf General DIY Discussions 10 01-15-2009 11:10 AM
Wall tiling trowl size help please. Hobb3s Remodeling 5 05-30-2008 07:45 AM
