Tiling An Inside Corner? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 04:50 PM   #1
Rewards Points: 105
Tiling an inside corner?
I am ready to tile my tub surround. I have mosaic going on the wall with the shower head and the rest of the tub surround will be a different tile. My question is how do I but the tiles? Should I run one wall of tiles to the corner and then but the other wall close or should I leave a small gap in each corner and have them butt up against each other this way?
If it does not matter which wall should be done first? I do not need have a center point on the main wall (longest wall) as the tiles are different. Thanks and merry xmas.
r1racer is offline   Reply With Quote
Old 12-24-2011, 05:12 PM   #2
DIY staff
Rewards Points: 7,174
Typically the back wall is set first--then the side walls---this way you are not looking straight at the cuts'
About 1/8" gap on the inside corners--knife out the grout while it's still wet --fill the corner with a color matching caulk.
r1racer (12-24-2011)
Old 12-24-2011, 05:38 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 07:25 AM
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 03:19 PM
Tiling around an outside corner abdoit Building & Construction 5 10-27-2009 06:04 AM
First coat on inside corner, need advise.. helpless handyman Building & Construction 6 09-24-2008 12:22 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
