Tiling Grout Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 09:05 AM   #1
Rewards Points: 49
tiling grout question
I bought "white" thinset mortar.
When i was tiling it came thru the tiles and now is level with the tiles.
especially around the small border tiles.
should i now forget the grout and finsih it off with the thinset?
any water type problems with that?
john_bry is offline   Reply With Quote
Old 03-19-2013, 09:10 AM   #2
Rewards Points: 12,828
Sure will be, that should have been cleaned off as the tile went up.
It all needs to be clean out now.
An ossilating tool with a diamond blade will make quick work of it.
Old 03-19-2013, 10:10 AM   #3
Rewards Points: 49
why would thinset mortar have water issues?
Old 03-19-2013, 02:26 PM   #4
you can put peanut butter between the tiles if you want to.
joe is trying to tell you the right way it should be done.
Old 03-19-2013, 09:31 PM   #5
Rewards Points: 918
I'm sick and tired of all this talk about peanut butter.
Some dumas is always suggesting to mix up the thinset to the consistency of peanut butter.
Now we've got peanut butter as grout.
NUTELLA is the stuff we want to start using. Everyone go out and buy a jar of nutella and get familiar with it.
cleveman is offline   Reply With Quote
Old 03-21-2013, 01:17 AM   #6
Registered User
Rewards Points: 4,912
Sounds as if you have too much material under it, correct notched trowel?
Gary
Old 03-21-2013, 02:17 AM   #7
747
registered
747's Avatar
Rewards Points: 534
I don't understand how this happened. Wrong size trowel or to much thinset or did you just push on the tiles to much?
Bottomline is this. If the thinset has setup your screwed. Well not screwed but its a pain in the ass to correct now. Go with joe's ideal.
747 is offline   Reply With Quote
Old 03-21-2013, 06:46 AM   #8
DIY staff
Rewards Points: 7,174
Joes idea is tried and true---a standard wood blade works,too---sometimes cut small to fit the smaller mosaics works well.
Just for the readers here-----mosaic tiles can be set with grout--and grouted as you set----
check with the grout manufacturers before doing this----
Several Youtube videos exist, showing this technique-------
Old 04-03-2013, 04:13 PM   #9
Rewards Points: 150
Always wear eye protection, especially when working with an oscillating saw. If the area isn't too large, you can also use a little grout saw.
zakany is offline   Reply With Quote
Old 04-03-2013, 04:46 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Keep a vacuum handy as you are going to make a mess and keeping the work surfaces clear will avoid any misses with the multi-tool.
Old 04-06-2013, 09:49 AM   #11
Rewards Points: 49
thanks all
Appreciate the input and comments.
I feel allot better after following Joe's recommendation to remove the thinset.
Old 04-06-2013, 10:12 AM   #12
Rewards Points: 258
Actually, thinset is a lot easier to remove than grout. Just a matter of time and effort.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
To cut the door or not? A tiling question forestk Flooring 5 06-19-2011 08:26 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
cracks in duracermic tiling grout ladymare Flooring 17 01-17-2010 12:19 PM
need help with a shower tiling question organick Tiling, ceramics, marble 32 09-12-2009 06:41 PM
What works and what doesn't to clean grout? groutresearcher Flooring 2 09-04-2008 11:49 PM
