#1 |
Tiling - Gap in plywood (sub)floor
I am in the process of remodeling a bathroom, and have taken it down to the studs and removed the old tile from the floor. The previous install had two layers of 1/2" plasterboard on each wall. Below the tile appears to be 1+" plywood. I will be installing new tile. They did the tile after the walls were in, so now there is a 1" gap where there is no plywood near the studs on the outside of the floor, and I would only like to put in one 1/2" sheet of drywall on the walls as the two layers seemed unnecessary. Once that is in, it will leave me with a 1/2" gap on the floor around the room that has no plywood.
I'm looking for suggestions to fix this. Is cement backerboard strong enough that if I put that over the plywood and the 1/2" gap, it will hold up? I know I could install strapping before drywall, but I'd prefer to get the extra 1/2" back into the room as it is pretty small already. I would also prefer to not go through the trouble of cutting 1/2" thick pieces of plywood to fill the gap. I also thought of just putting extra layers of backerboard in the gap. Thoughts? Thanks. |
#2 |
K&B Remodeler/Tile Guy
Why not fill with 1" strips of plywood before you drywall?
Angus To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Tiling - Gap in plywood (sub)floor |
#4 |
I understand. If I'm not mistaken, if you bought a sheet of plywood from the big box stores, don't they offer to cut it for you? I think I remember seeing the big panel sized cutting machines in there.
#5 | |
Tiling - Gap in plywood (sub)floorQuote:
Thanks! |
#6 |
Most box stores will cut it for you and they even sell helf sheets of plywood if you don't need a full one. I would support that last 1/2" of cement board if it was me.
| Display Modes | |
| Fastening Subfloor Plywood To Concrete Slab | Hages | Flooring | 9 | 01-15-2009 12:07 PM |
| Plywood underlay to subfloor - size screw? | ygeorgiay | Flooring | 3 | 08-01-2008 12:36 PM |
| Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood | italoblu | Flooring | 2 | 07-31-2008 01:11 PM |
| Subfloor / underlayment question... | scheenstra | Flooring | 7 | 02-21-2008 08:39 AM |
| Builder applies coating to plywood subfloor | Christopher | Building & Construction | 5 | 12-20-2006 10:19 AM |
