Tiling Fireplace: Granite Over Sheetrock - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 12:49 AM   #1
Tiling fireplace: granite over sheetrock
I would like to tile around my fireplace using 12X12 granite tiles. It is currently surrounded by sheetrock. What materials should be used in such installation? Will thinset over sheetrock suffice?
Thanks.
digexpressions is offline   Reply With Quote
Old 03-04-2008, 04:32 PM   #2
Thanks.
You will have to use Hardibacker or another concrete board. Personally, I would carefully remove the drywall and screw the concrete board to the studs. After the concrete board is in place, you can tape the joints with drywall mud or Durabond. Then, you can use thinset to set the tile.
Here is a link for you information:
http://www.jameshardieeu.com/pages.p...ubpage=hbacker
Handyman50 is offline   Reply With Quote
Old 03-04-2008, 05:19 PM   #3
Tile Contractor
Bill_Vincent's Avatar
Not at all. Thinset over sheetrock will be fine. The only time CBU is needed is if the area needs to be fire rated (and for fireplace inserts, it's not required in most jurisdictions) or if it's a wet area.
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 03-07-2008, 10:52 AM   #4
I did mine exactly like what you want to do with granite directly on sheetrock 3 years ago... and it is still standing strong today.... ...
but due to the weight of those heavy tiles.... you need to put nails to support them before the thinset dryout.... when installing... see you can tell I have this one time experience before....
KUIPORNG is offline   Reply With Quote
Old 03-07-2008, 02:45 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
FWIW: Installation on the sheetrock is fine, for the reasons that Bill stated. This is in regards to normal applications. However, in your application, it's different:
KEY FIREPLACE ISSUES: Please check your local codes regarding fireplace/firebox requirements and proximity of combustable materials....and the type of fireplace system that you have.
Examples:
http://www.woodweb.com/knowledge_bas..._clearance.JPG
http://www.manteldepot.com/building_code.htm
- Build Well -
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 09:16 AM
tiling a fireplace Jack Hass Remodeling 2 07-28-2008 09:04 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
Tiling inside a fireplace Patricia Building & Construction 4 09-02-2006 07:51 PM
