Tiling Bathrooms.. - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2006, 09:31 AM   #16
Rewards Points: 123
Originally Posted by KUI****G View Post
Well if there is existing tiles you need to pull out, that prbably means damaging the drywalls and that probably means reinstalling drywalls... that is labour works making the 2200 more justifly... although I never done tearing down things... don't know if it will damage existing drywalls... but wouldn't surprise it will do so as the cement is really strong...
anyhow... I will still DIY... consider the knowledge you will gain after doing this project... book reading is still a key to success rather than just jump right into it...
Sorry for the piece meal information. I should have mentioned this. The tile exists on the floor only. I would like to tile the walls as well, not including the walls around the tub since the existing tub/shower is a single enclosure. The price I was given included the walls. I think I am going to tackle this myself.
jerome8283 is offline   Reply With Quote
Old 09-18-2006, 01:29 PM   #17
may be it is your area... but to do what you describe and cost $2200 labour alone is a bit overcharge to me... unless you have a 300 sq.ft. luxury bathroom...like message from upstairs... may be to remove old tiles work does cost a lot which I am not aware off, I used to hire contractor to lay floor tiles in my half bathroom for $200 Canadian labour... but that was 4 years ago...
KUIPORNG is offline   Reply With Quote
Old 01-22-2007, 11:45 AM   #18
If you are going to do Concrete backer board you could remove the old wall, flooring and have those items in place for a handy man to come in and do the actual layout and tiling. Often a heafty piece of the cost is the tear down and the disposal. Another minor detail might be that the tailpiece may no longer reach to the p-trap, but a trip to the plumbing dept. should fix that. Well i am in the middle of bathroom remodeling too. And I am desperatly looking for more informationr regarding this topic, so If you could post some website that help a lot....please don't post this website remodel-bathrooms.com as I already know about it. thanks in advance
kathy
links is offline   Reply With Quote
Old 01-23-2007, 09:51 AM   #19
Your tile work looks great. I notice you've left a window in the shower. Is it just tiled and then grouted to the glass? I currently have my bathroom down to studs. Old house and still has the frame of the old double hung window. I want to put glass block in that hole. It runs down to within 6 inches of the tub. I thought if I made it flush with the tiled walls it should hold up as well as the tiles. Sound possible? And if I can just ask another question here (I'll probably post elsewhere too), is it possible to tile the ceiling? I want to use 20" tiles on the walls, but I'm worried about such a heavy tile being overhead and knocking me out some day. Any suggestions?
Teko is offline   Reply With Quote
Tiling over a bathtub lip The Kid Remodeling 19 02-04-2012 11:46 AM
Ceramic Tiling on a Slab nsb318 Flooring 3 03-01-2007 02:23 AM
Bathrooms? newbiebuild Plumbing 8 07-31-2006 01:06 AM
How scuffed should old tile be before tiling over w/ new J187 Flooring 3 07-25-2006 08:01 PM
bathroom tiling neptunian General DIY Discussions 1 03-29-2005 07:44 AM
