Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-11-2011, 07:55 AM   #1
Tiling a bathroom
Over the weekend installed a new shower over bath and tiled around the bath and wall area. Planning to grout the tiles tomorrow, however unsure of a couple things.
How long does the grout need dry before the shower can be used?
Do you seal the grout straight away or wait? Seems to be many opinions on when this should be done
stevodevo is offline   Reply With Quote
Old 12-11-2011, 08:44 AM   #2
Super Moderator
Tiling a bathroom
What kind of grout? Conventional cementisious (sp) --24 to 48 hours---sealer? read the label-they vary.
Epoxy---24 hours or less--no sealer---
Acrylic----7 days---no sealer
Old 12-11-2011, 10:55 AM   #3
Contractor
aureliconstruct's Avatar
Tiling a bathroom
For regular grout you should wait 24 hours. Sealing is not needed, but if you have a problem with mold and the bathroom is not well ventilated, you should apply a sealer, especially if the tiles are natural stone. In fact, you should always seal natural stone and the grout.
aureliconstruct is offline   Reply With Quote
Old 12-12-2011, 11:35 AM   #4
robertBny's Avatar
Tiling a bathroom
To grout your tile wait approximately 8 hours after installation, this is plenty of time to let the glue dry and not let your tiles move around from grouting. As far as sealing I do recommend sealing your grout as this will prevent mold buildup on the surfaces of the grout but in my opinion wait at least 1 week if not 2 to seal to allow the glue and grout to completely "cure." Doing so prematurely could lock in moisture and never allow the grout and glue to dry properly.
robertBny is offline   Reply With Quote
Old 12-12-2011, 11:49 AM   #5
Tileguy
Bud Cline's Avatar
Tiling a bathroom
Opinions opinions, everyone has an opinion. This isn't up to someones opinion. Various sealers have various recommendations. Follow the instructions on the label of the grout sealer you buy. It's just that simple. Leave every one's opinion out of the mix in this case.
Help! Tiling Bathroom Floor DigitalHammer Flooring 14 10-26-2011 08:29 PM
Bathroom tiling yochujr Drywall & Plaster 12 01-19-2011 12:30 PM
bathroom tiling del61nj Tiling, ceramics, marble 7 01-17-2011 04:12 PM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 12:44 PM
bathroom tiling neptunian General Discussion 1 03-29-2005 08:44 AM
