Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-08-2008, 07:43 AM   #1
tiles on brick
Hi, back again modelling going well but need to know if it is better to put tiles directly onto brick wall or to put villaboard up first and if I do put villaboard up do I adhere it direct to bricks or put up battens, then villaboard then tiles?
Irwinbuilt
irwinbuilt is offline   Reply With Quote
Old 01-08-2008, 09:43 AM   #2
tiles on brick
Is it an exterior wall? Are any cracks showing? Need more info.
maticus is offline   Reply With Quote
Old 01-09-2008, 05:49 AM   #3
Post
tiles on brick
What I have is 3 cavity brick walls and one villaboard wall in what was three rooms but is now one. I have put battens on the lower half of the brick walls and put v groove sheeting up which will have a dado rail on the top. The false wall has allowed the plumber to put in new piping and I have set up new 1300 corner bath in place. New 3/4 walls are going up around the toilet for privacy and tiles are to go above the panelling. the battens are 42 x 19 mm, the panelling 9mm and the dodo rail rebates back over the panelling making a distance of 19cm out from the brick. what I think I should do is put up 42x8mm battens, then the 6mm villaboard allowing a deepth of 5mm for the tiles and adhesive. What do you think?
Also I have to have a step in front of my bath as the plumbing has made it a little high any help with this would be appreciated. Sorry everything in the room is in very good condition no cracks, level and pretty square as this house was built by my ex and I and is 28 years old I am quite proud of it.
It is looking good and I am very pleased with the change so far.
MaryAnn
Last edited by irwinbuilt; 01-09-2008 at 05:53 AM. Reason: forgot to answer question
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
