-   -   Tiles before or after kitchen cabinets? (http://www.diychatroom.com/f15/tiles-before-after-kitchen-cabinets-51292/)
nipab 08-20-2009 09:31 AM
We are changing our kitchen cabinets, counter top, back splash and floor tiles. Cabinets are coming next week, what I want to know is
1. Do we need to remove existing back splash before installing new cabinets? Do I need to install new back splash before cabinets too?
2. Same for floor tiles. Does it have to come off before installing new cabinets and do I need to install new tiles before installing new cabinets?
Which one is easier and economical, installing tiles before or after installing cabinets? Or it doesn't make any difference.
Appreciate any response.
Bob Mariani 08-20-2009 05:23 PM
Floor tiles first. Then cabinets. Then backsplash tiles.
Gary in WA 08-20-2009 07:37 PM
A lot easier to get the under-counter dishwasher, refer, compactor, in/out. Be safe, G
Just Bill 08-21-2009 06:29 AM
1. Yes, remove old BS reqardless of the type, patch damaged drywall. If new BS will Formica or similar, install first; if tile, it goes on last.
2-3. Mixed thoughts on that, some prefer to tile the whole floor first then do cabinets. I do cabinets first then tile, especially if my customer has selected expensive tile, why waste it under a cabinet. The likelyhood of damage to tile is high during installation. I also tile under appliances.
Scuba_Dave 08-21-2009 07:56 AM
I prefer a clean slate for a remodel, wall tiles are last
One note on the floor. If using tiles make sure you dishwasher/undecounter appliances will fit
Many people install the tile & cabinets & then find they can't slip the dishwasher in
OR
They have it all installed & find they can't get the dishwasher out
I usually space my cabinets up off the floor to allow for the height of the tiles
This house getting the new fridge in was a pain due to 2 layers of flooring & the overhead cabinet
bjbatlanta 08-29-2009 09:04 AM
Ditto what Scuba Dave said. I had to cut down an existing "over the fridge" cabinet for a friend so his new refrigerator would fit after he had his floor tiled. That was a pain...
omakite 01-03-2015 02:12 PM
If you tile before installing the cabinets how do you anchor an island to the floor?
ZZZZZ 01-03-2015 05:02 PM
how do you accomplish this? Do you put a section of OSB or plywood over the subfloor?
oh'mike 01-03-2015 06:02 PM
Glue two 2x4 blocks to the tile--screw the cabinet base to the blocks--
If you are in a hurry and can't wait for the builders adhesive to dry--drill the tile and use long screws.
PD_Lape 01-05-2015 11:19 AM
Floor tiles should always be first doing it the other way will be more time consuming, not to mention messy. You do not want to reconfigure the cabinets just because everything won't fit or open after the tiles are installed.
