Tile Or Wood Baseboard In A Home? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 07:32 PM   #1
Question
Tile or wood baseboard in a home?
We are remodeling our home with tile throughout most. Does it matter whether we use tile or wood baseboard - I was told you typically use tile baseboard in commercial use not residential? And wood baseboard in residential? Tile cost more, less maintanence. Wood more traditional & cost more. From a designer stand point which looks better & Is it just a preference?
Wahbehwoo is offline   Reply With Quote
Old 09-27-2012, 08:24 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
It depends if you want the baseboard to match the design of the interior trim around the windows and doors...
hand drive is offline   Reply With Quote
Old 09-27-2012, 08:41 PM   #3
personally i like baseboard. i replaced all the 3 inch base with 7 inch when i redid my house. on the tile floors and the hardwood floors. all painted with a satin oil paint.
Old 09-27-2012, 08:57 PM   #4
AHH, SPANS!!!
Larger base especially helps in homes with taller ceilings and plinth blocks along the door openings...
Old 09-27-2012, 09:40 PM   #5
Rewards Points: 960
You can do whatever you like.
Wood is used more in the US, but it is very common to use tile elsewhere.
I like the practicality of tile. It will allow you to mop the floor and not worry about getting the "mopboard" wet.
The wood baseboard is getting cheesier and cheesier. I think you are lucky to find a 7/16 x 3" high board now.
It won't be any more expensive to use tile, depending on your circumstances. How do you plan to terminate the top?
cleveman is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Matching baseboard to tile janralix Carpentry 2 12-10-2011 08:33 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
extending hearth tile over wood floor Queso Bandit Flooring 0 11-22-2010 01:28 PM
Tile Baseboard for Loghome sassyalice Flooring 0 08-06-2010 09:30 PM
