-   -   Tile or wood baseboard in a home? (http://www.diychatroom.com/f15/tile-wood-baseboard-home-158199/)
Wahbehwoo 09-27-2012 07:32 PM
We are remodeling our home with tile throughout most. Does it matter whether we use tile or wood baseboard - I was told you typically use tile baseboard in commercial use not residential? And wood baseboard in residential? Tile cost more, less maintanence. Wood more traditional & cost more. From a designer stand point which looks better & Is it just a preference?
hand drive 09-27-2012 08:24 PM
It depends if you want the baseboard to match the design of the interior trim around the windows and doors...
DannyT 09-27-2012 08:41 PM
personally i like baseboard. i replaced all the 3 inch base with 7 inch when i redid my house. on the tile floors and the hardwood floors. all painted with a satin oil paint.
hand drive 09-27-2012 08:57 PM
Larger base especially helps in homes with taller ceilings and plinth blocks along the door openings...
cleveman 09-27-2012 09:40 PM
You can do whatever you like.
Wood is used more in the US, but it is very common to use tile elsewhere.
I like the practicality of tile. It will allow you to mop the floor and not worry about getting the "mopboard" wet.
The wood baseboard is getting cheesier and cheesier. I think you are lucky to find a 7/16 x 3" high board now.
It won't be any more expensive to use tile, depending on your circumstances. How do you plan to terminate the top?
