Tile Tub Surround With Window - Remodeling - Page 4 - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 07:13 PM   #46
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The cement board is installed short of where I would have placed it. I would have continued it the the corner then lapped it with the corner trim using adhesive. THEN...the difference between the surface of the trim and the surface of the cement board would be filled with thinset. That product you have there is really too thick. You could have asked Hensel's who they sell to (drywall installers) and probably bought a couple of pieces from them.
Your on your own with that plan.
Old 11-13-2011, 06:46 PM   #47
Just wanted to post an update on how everything turned out. For my first tile job I think it turned out pretty good
Now I just need to figure out what I want to do at the top of the tile where the tile and durock meet the drywall...
mxingislife is offline   Reply With Quote
Old 11-14-2011, 10:07 AM   #48
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Huge gap at the tub! Is that gap filled with grout or caulk?
Old 11-14-2011, 11:06 AM   #49
I know that was my big flaw in this job. The gap ranges from 1/4" up to 1/2" in some spots. It has caulking behind it and then grout.
Old 11-14-2011, 11:11 AM   #50
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Bummer! Unfortunately you can expect the gap to crack. When it does...the grout should be replaced with caulk. Not an easy task with a gap that big.
You could also consider adding some bull-nose along the tub. This would hide the gap but create two junctures to be caulked. May look better.
Overall the job looks great.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Tile Tub surround golfer2b Flooring 26 08-30-2008 01:25 PM
