Tile Tub Surround With Window - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 04:58 PM   #31
A couple other questions, what about where the durock and drywall meet, should I use tape and drywall mud to cover the joints? Or some other method?
My tub is 30" wide and I am using 12" x 12" tile and 3" x 12" bullnose that I want to border the outisde perimeter. To keep the tiling to the same 30" width of the tub should I cut my 12's to 3" in the corner and then run two more 12" x 12" and finish it will a 3" bullnose? Will it look weird with 3" in the corner?
Or, should I cut the 12 down to 6" in the corner and run two 12" x 12" and then finish it with a 3" bullnose? If I do that, I will have to extend the durock and tile 3" past the tub. What do you recommend?
mxingislife is offline   Reply With Quote
Old 11-04-2011, 08:07 PM   #32
I determined that I need to fur the studs out about 1/2" to reach the tub lip before attaching the cement board. And I need the thinnest cement board so it doesn't stick out too far past the existing drywall. I was hoping I could buy 1/4" durock, but it only comes in 1/2" but James Hardie, Hardie Backer Cement board comes in 1/4". Can I use this around by tub to put the tile on? I will still cover the entire surface of the cement board with RedGard.
Old 11-04-2011, 08:13 PM   #33
Question
HardieBoard or Durock?!
I need to use thin cement board (hoping for 1/4") for my tub surround to put tile on. In order for the board not to stickout too far from the existing drywall 1/4" would be best.
James Hardy, Cement HardieBoard comes in 1/4" but it says it is for floors and countertops, but the local home store said I could use it for a tile tub surround.
Can I use the HardieBoard for my tile tub surround or do I need to use the 1/2" Durock?
Old 11-04-2011, 08:21 PM   #34
Tileguy
Bud Cline's Avatar
Rewards Points: 558
1/2" is the minimum thickness that can be installed on wall studs.
All cement boards do come in 1/4" but they aren't to be used for walls.
Old 11-04-2011, 08:24 PM   #35
Why can't 1/4" be used to attach to wall studs?
Old 11-04-2011, 08:31 PM   #36
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not thick enough, not rigid enough, too flexible, grout won't stay, contrary to code.
Old 11-04-2011, 08:38 PM   #37
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you kidding?
Just minutes ago we discussed this in your other thread.
Do you think I'm telling you lies when I tell you 1/4" shouldn't be used? Do you think you will get more support if you start a new thread?
Keep all of this on one thread so it isn't so confusing for everyone.
Old 11-04-2011, 08:54 PM   #38
Msradell's Avatar
Rewards Points: 172
While you have the walls open I would also replace that galvanized piping with either PEX or copper depending on your preference. No sense in doing all this work and then having problems with your pipes.
Msradell is offline   Reply With Quote
Old 11-04-2011, 08:58 PM   #39
I had the plumber here yesterday and he cut the galvy out ran new pex and copper
Old 11-04-2011, 09:06 PM   #40
Msradell's Avatar
Rewards Points: 172
Old 11-04-2011, 09:16 PM   #41
Registered User
Rewards Points: 5,482
Please post exact same question in one forum, thank you. I merged your others....
Gary
Old 11-04-2011, 09:36 PM   #42
Are you kidding?
Sorry Bud Cline, I posted the other thread before I got your first response. I wasn't going against your knowledge. I appreciate all of your info and trust it! I really appreciate all of your help
1/2" durock it is.
Old 11-04-2011, 09:37 PM   #43
Gary
Thanks Gary
Old 11-05-2011, 01:04 AM   #44
Just an update as of this evening. Durock goes up tomorrow.
New Plumbing...
Old 11-06-2011, 05:29 PM   #45
Hey Bud Cline I called Hensel's to try and get some of the plastic j bead for around the window. They told me they were out and they could order me some but I would have to buy a case
So I went looking around and found some FRP Molding and each side is 1 3/8" which is exactly the measuremrnt from my window to the durock.
How would you recommend attaching this? With thinset underneith one of the lips and maybe some nails? Should I tile up to where the corner is or stop tiling where the molding starts?
See pics below...
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 08:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Tile Tub surround golfer2b Flooring 26 08-30-2008 12:25 PM
