So you recommend going with the RedGard on the durock and not using a vapor barrier on the studs?
You betcha!
What are the positives on going with that option as opposed to the vapor barrier on the studs?
The positives are you won't be saturating the cement board with water to run down behind your tub/tile caulked juncture, and developing mold will be less likely. Not that mold would be an issue anyway but there won't be the moisture necessary to feed the mold.
I'm just trying to figure it out because I will have to spend about $100 on RedGard.
No you won't, one gallon/bucket will easily cover an entire tub surround. In fact you can add water to it if you like and cut it by 30 percent. That's what I do to get it to sink into the face of the Durock. I generally apply two maybe three coats and all from a single gallon/bucket.
The local tile store gave me the roll of tar/felt type paper to go over the studs and just charged me $6.00 and told me to bring the roll back when I was done.
You can't do both. That's three times I said it now.
We were talking about insulating below the tub line. That sometimes gets overlooked and the answer is yes. Same for the walls above the tub.
