Tile Subfloor Help - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 05:48 PM   #16
K&B Remodeler/Tile Guy
angus242's Avatar
Actually, I'd remove the planks. Not sure what their purpose was. Anyway, if the subfloor is truly 1 1/14" ply, I'd put the backer over that. If you install the CBU over the planks, you'll have a situation that I personally have never encountered.
When you install CBU, you use a 1/4" notched trowel and spread thinset over the subfloor. The CBU is laid over the thinset and then screwed down. The seams are addressed as I mentioned.
So now you see the issue of the planks. If there aren't any gaps between them, I suppose you could put the CBU over them. However, if there are gaps, the thinset will fall through and you'd need a lot more thinset to make sure the CBU has a firm base to reside on.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-14-2009, 09:40 AM   #17
I'm probably going to just use the thinset. I have no idea how I would remove the planking flush to the walls.
wineslob is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
