Tile Size Does It Matter:) - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 06:52 PM   #1
Tile size does it matter:)
Hello, I'm redoing my bathroom and I bought tile that is 3/8" thick and it is 3"x6" subway tile can we uses this on the shower walls or is it too thick. ?? thank you guys Im confused!!!
Snickers123 is offline   Reply With Quote
Old 02-07-2012, 07:00 PM   #2
Rewards Points: 13,446
Thicker should be less likly to crack so it should be fine.
Old 02-07-2012, 07:07 PM   #3
DIY staff
Rewards Points: 7,174
Some of the hand made subway tiles from Spain and Italy are thick like that---they looks good--make sure you have matching bullnose and you are good to go.
Old 02-08-2012, 11:26 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
When I re-tiled our shower (only my second tiling project) I used 1/4" porcelain floor tile, and installing our shower control was close. Plan ahead and make sure your plumbing will work with tile that thick.
Tile size pros and cons for bathroom wall. Jim F Kitchen & Bath Remodeling 12 02-29-2012 10:11 AM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
What size floor tile? skipjack Flooring 1 09-22-2008 10:39 AM
