Tile Sink Grout Removal - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 12:28 PM   #1
Hi all - I have a tile sink in my bathroom and it looks like the grout is against the wall. Is there any tricks to removing the grout from the wall in order to remove the sink cabinet unit? I'm trying to put a picture on here, sorry it is sideways. Also, will I have to re-drywall the area? Thank you in advance
tonyinaz is offline   Reply With Quote
Old 04-04-2013, 05:31 PM   #2
Rewards Points: 14,312
No one here is going to know exactly how that backsplash was attached to the wall.
Could have been plywood, tile board, they could have used mastic, thinset?
More them likly the drywall will be trashed trying to get it off.
Trying to match that knocked down texture is going to be the hard part.
Old 04-04-2013, 06:18 PM   #3
That's what I was afraid of. I guess my little bathroom remodel is going to be a bit tougher then I thought. Thanks.
Old 04-04-2013, 06:47 PM   #4
They always are.
Make sure to change the shutoffs and supply lines and anoy old steel drain lines.
Old 04-04-2013, 09:42 PM   #5
Rewards Points: 240
if you not trying to save that tile. use a hammer and chisel and carefully chip away at it.
Fix'n it is offline   Reply With Quote
Old 04-05-2013, 02:23 AM   #6
Rewards Points: 744
Originally Posted by joecaption View Post
They always are.
That was my exact thought as well. What started out as simply replacing my vanity turned into discovering a 20yr water leak (drywall screw had pierced hot water line). So, a bit of cursing, mold cleanup, plumbing fix, cursing, drywall replacement, and a big smile once it was all done.
Seattle2k is offline   Reply With Quote
Old 04-05-2013, 06:20 AM   #7
DIY staff
Rewards Points: 7,174
If the top is to be destroyed----use a multi-tool to cut grout at the wall---then smack and crack off the back splash tiles-----look for screws or nails that are holding the splash to the wall---
No multi-tool? Use a 5 in one painters tool like a big chisel and split the grout away from the wall---
Old 04-05-2013, 08:00 AM   #8
Rewards Points: 150
They always are.
I dunno. My master bathroom was so poorly constructed that demo was entirely too easy.
zakany is offline   Reply With Quote
Tile Grout Jwindsor Tiling, ceramics, marble 0 03-17-2012 03:12 AM
Need tile suggestions for a backsplash / low window behind sink CoconutPete Kitchen & Bath Remodeling 10 03-10-2012 10:42 AM
Cleaning grout lines/shower tile question Pawl Flooring 0 02-17-2012 03:03 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
