Tile Shower Replacement With New Tile - Remodeling - Page 5 - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 08:50 PM   #61
DIY staff
Rewards Points: 7,174
You should be fine----my bath is on the same line as a bed room---that's why I suggested you check---
Old 08-06-2013, 08:26 PM   #62
Axhammer's Avatar
I finished installing the drain, installed some vapor barrier and some backer board, and fabricated a couple nooks. I plan on pouring mortar mud, and getting the pan shaped in th morning. Then I get to take the afternoon off and go see a movie with the family.
Pure-Pontiac
"See ya at the drags"
Moyock NC
Axhammer is offline   Reply With Quote
Old 08-06-2013, 08:30 PM   #63
Axhammer's Avatar
One of the nooks.
Pure-Pontiac
Moyock NC
Old 08-06-2013, 08:34 PM   #64
Axhammer's Avatar
I forgot to replace the shower head pipe while I had the system drained yesterday, I need to drain it so I can replace the pipe, before I put up the backer board on this wall.
Pure-Pontiac
Moyock NC
Old 08-06-2013, 08:40 PM   #65
Axhammer's Avatar
Ready for mud, in the morning, as soon as I can get the tar paper and expanded steel mesh in place. I'm hoping to be finished working on it by noon.
Pure-Pontiac
Moyock NC
Old 08-06-2013, 09:20 PM   #66
DIY staff
Your use of the word 'pour' has me concerned--pack is the right word---deck mud is rather dry and is packed---and shaped with the edge of a trowel----
Old 08-07-2013, 07:58 AM   #67
Axhammer's Avatar
Yes, I used the wrong word I suppose. I saw a video that claims when you can take a hand full of the dryish mix, and pack it together like a snowball, it is at a good consistency. Anyway, I'm getting ready to turn-to, I'll post up some picks after its "packed & troweled". Thanks for the input mike, I appreciate it!
Pure-Pontiac
Moyock NC
The Following User Says Thank You to Axhammer For This Useful Post:
oh'mike (08-07-2013)
Old 08-07-2013, 12:57 PM   #68
Axhammer's Avatar
I used two and a half bags of 4/1 mortar mud. I mixed a baba and a half hoping it would be enought to do the job. I had to mix a second batch when I realized it Wasent enough. I think the second batch was a Lille wetter than the first, as a lot of water floated to the surface. I sprinkled some dry mix on top after I was finished.
Pure-Pontiac
Moyock NC
Old 08-07-2013, 12:58 PM   #69
Axhammer's Avatar
Final results.
Pure-Pontiac
Moyock NC
Old 08-07-2013, 02:43 PM   #70
DIY staff
That is what? the preslope?
Did you read the link I posted?
Yikes---next step is the liner---folded --no cuts---
then the durrock----after that the pan mud---but jezz---that stuff should be as dry as beach sand---read the link----just enough water to dampen the mortar enough to stick together when packed like a snow ball---
Old 08-07-2013, 07:12 PM   #71
Axhammer's Avatar
Yes, it is ready for the membrane, same stage as pic #9 in your link. I put a level on all sides and I'm happy with the way it turned out. I better run to HD in the morning, I used two and a half bags (of three) so far. How thick should the top layer be? I think I'll get three more bags, better to have and not need, than to need and it have. Plus I have to do the step. Will I be able to walk on this tomorrow? Or should I wail a couple days?
Pure-Pontiac
Moyock NC
Old 08-07-2013, 07:17 PM   #72
Axhammer's Avatar
So far I happy with it, I'll run the shower after the membrane is installed to see how well it drains.
Pure-Pontiac
Moyock NC
Old 08-07-2013, 09:11 PM   #73
DIY staff
1 1/2" to 2" is the typical depth of the deck mud ---
Old 08-08-2013, 08:58 PM   #74
Axhammer's Avatar
Installed the membrane, and the rest of the backer board in the shower. Next I need to install the backer board in the shower entrance jamb, tape & mud all seams and pack the final layer bedding mortar, and form the curb.
Pure-Pontiac
Moyock NC
Old 08-08-2013, 09:00 PM   #75
Axhammer's Avatar
Next I get to replace my vintage medicine cabinet.
Pure-Pontiac
Moyock NC
Shower pan/ tile problem Pawl Tiling, ceramics, marble 8 01-16-2012 09:32 AM
Shower Tile Issues Clover Plumbing 0 11-11-2011 08:54 PM
Repairing ceramic tile shower jimmyj Building & Construction 1 04-25-2011 08:09 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
