Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-14-2010, 03:58 PM   #1
Question
Tile over sheetrock
Hello
We've recently been doing some work on our 80s built house, including replacing a tub surround in one of the bathrooms. The original surround was three solid pieces of cultured marble. I don't do tile so I pay to have that work done, using a local crew I've been using for years for various stone and tile projects. My question is this: They smoothed the leftover glue and applied the thinset and tile directly onto the original sheetrock, which was in good condition. I was made aware later that this probably wasn't ideal and new backer board should have been used instead. Do I have cause to worry here? The grout has been sealed with a silicone sealant as well. If I should expect problems, how long until then?
thanks.
mcgruff is offline   Reply With Quote
Old 01-14-2010, 04:27 PM   #2
jlhaslip's Avatar
Tile over sheetrock
as long as the tile backer stays dry, you will not have a problem.
lots of shower stalls have been this way for years.
Is it the best method? nope.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 01-17-2010, 04:28 PM   #3
Drywall contractor
Tile over sheetrock
Be sure to keep it well caulked. Tile backer should have been used......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-18-2010, 12:16 PM   #4
Stuck in the 70's
Blondesense's Avatar
Tile over sheetrock
Is this tub only, or tub/shower combo?
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Hanging Sheetrock Over Tile cbug21 Remodeling 11 09-18-2009 06:17 PM
Sheetrock Over Tile Anyone? CallieT Remodeling 5 02-14-2008 10:14 PM
Tile over Sheetrock zmurphy Building & Construction 9 06-23-2007 04:45 PM
