Tile Over Paneling? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2007, 10:06 PM   #1
Tile over paneling?
I'm planing on using modular granite tiles to tile my kitchen counter tops. I would also like to add a backsplash. Problem is the kitchen walls are paneling. The paneling was put up first of course and the cabinets then attached to the wall. I don't see a way to effectively replace the section between the top and bottom cabinets and make it look right. If I add anything to it (backerboard, drywall) it looks like it will protrude too far out. So can I tile over the paneling?
thanks
Eric_ht is offline   Reply With Quote
Old 11-23-2007, 10:25 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro tiler, but everything that I've ever heard about tiling over any type of wood is that it will eventually crack the tile and/or the grout due to expansion and contraction.
Can't you cut it out and replace it with thin cement backerboard?
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-24-2007, 09:27 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
1/4" hardy backer board at bear min. Make sure you nail evey stud and back it with so liquid tales or thin set. This is the cheap may to do it right 1/2"
Kingfisher is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 07:15 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
