Tile Over Laminate Countertop - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2014, 10:55 AM   #1
Question
Tile over laminate countertop
I've read that you can put tile over laminate if you sand it with a 60 grit sand paper to rough the surface up. I'm putting 4x4 bright snow white tiles on the counter top (mainly to match a pre-existing white tiled wall).
So, I've sanded the counter-top with my orbital sander, but I'm not so sure that it is roughed up enough... how do you tell what is rough enough? The gloss is gone, but it doesn't feel that rough to the touch, to me anyway.
Anyone have any recommendations? I can't pull and replace the counters, and there are 3 corner cabinet garages that inhibit putting any kind of backboard down.
Suggestions? Will this work? Anyone experience with tile over laminate?
Thanks for any thoughts and advice!
MrsEmPeel is offline   Reply With Quote
Old 04-21-2014, 11:33 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,624
Yep..... I've done it once before.... I use a belt sander.... and all gloss is gone and it feels roughened.
Use a good quality modified (latex) thinset.
(I never encountered any problem, my laminate was a solid substructure.)
Maybe Jazz will advise further.
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
MrsEmPeel (04-21-2014), Windows on Wash (07-15-2014)
Old 04-21-2014, 11:43 AM   #3
What do you suggest as a "good modified latex thin-set"? I have SimpeSet Pre-Mixed Thin-Set Mortar, but can easily return. W ould this work, or not?
Old 04-21-2014, 05:06 PM   #4
I'm really not familiar with Simset or any Pre-mixed product.... does it say polimer modified.
I generally use Custom (company brand name) VersaBond or Multi-Set.
But any BigBox or Tile Store will be able to direct you to their latex or polimer modified thin set..... everybody makes it.
Old 07-09-2014, 11:36 AM   #5
I think this should be fine.
europaving is offline   Reply With Quote
Old 07-09-2014, 12:41 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DO NOT USE PRE-MIXED MORTAR on a laminate counter top, it won't stick for very long. Buy MODIFIED THINSET in a bag and mix it yourself.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
joecaption (07-15-2014), Windows on Wash (07-15-2014)
Old 07-15-2014, 08:10 AM   #7
Rewards Points: 518
It can be done, but I would actually score the top with carbide tip laminate cutter, or at least hand sand with 30 or lower. Orbital with #60 is still too glossy, I think.
For countertop, I would use tile glue instead of thinset. Glue has better stick-tuitiveness to plastics than thinsets.
carpdad is offline   Reply With Quote
Old 07-15-2014, 10:39 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Amazes me every time it happens.
XXX
Old 07-15-2014, 04:24 PM   #9
Rewards Points: 518
True, lol. Old glued tiles were the easiest to demo since they just popped off glossy underlayment.
Old 07-15-2014, 09:34 PM   #10
Rewards Points: 940
I haven't done a lot of research, but I can't think of anything which the thinset doesn't stick to very well. It will stick to all my tools, plastic buckets, shoes, clothes, skin.
cleveman is offline   Reply With Quote
Old 07-15-2014, 10:27 PM   #11
Rewards Points: 144
Me too! I'd type more but I'm on the way to get me some tile glue.
mako1 is offline   Reply With Quote
Tags
backerboard , countertops , laminate , rough , tile adhesives
(un)bending laminate countertop chenzarino Kitchen & Bath Remodeling 11 10-12-2014 11:23 AM
Cutting a radius on a stock laminate countertop ponch37300 Kitchen & Bath Remodeling 12 05-05-2013 08:06 PM
baseboard- tile and laminate floor same room fredaL Flooring 0 12-10-2010 09:45 PM
asbestos tile under laminate? bubbler Flooring 1 12-05-2010 02:53 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
