#1 |
Tile over brick
Hi,
I want to reface an old brick fireplace with tiles. These are sort of unevenly laid "carpet" bricks. (grooved surface). I figure that attaching hardy backer first to the bricks will get me the smooth surface I'm after. So, what's the best way to attach the backer board to the bricks? Thinset, construction adhesive, screws or a combination of these things?
I'm gonna hurl myself against the wall because I'd rather feel bad than not feel anything at all Warren Zevon |
#2 |
Tile over brick
Post a picture of what you have to work with.
Ron |
#3 |
Tile over brick
Clean the brick. Rinse well and let it dry. Mist the brick lightly with water and apply a modified thinset skim coat and let dry. The backerboard will not be needed (nor would I recommend it, unless you can find a fireproof backerboard) if you can get the surface flat enough to apply tile. Otherwise you will need at attach a metal lath with tapcons and skim coat it with a type S mortor. Need a pic.
Work is for those who can not fish. |
| Display Modes | |
| Removing Tile Over Hardwood: Need Help With Kitchen/Bath | Creelove | Flooring | 3 | 02-01-2011 07:03 AM |
| Ceramic tile over asbestos tile question | MLMIB | Tiling, ceramics, marble | 4 | 01-10-2011 08:58 PM |
| HELP! with brick tile floor | cpmathis | Flooring | 0 | 09-03-2010 11:58 AM |
| Question Re. Parging Over Brick | Captain.Sassy | Building & Construction | 19 | 06-22-2010 09:50 AM |
| Insulating brick above & close to grade | Peter Shepherd | Building & Construction | 1 | 09-16-2009 07:41 AM |
