Tile Grout Pulling Out While Removing Caulk - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 06:02 PM   #1
Rewards Points: 506
Tile grout pulling out while removing caulk
In the process of removing nasty plastic trim and nasty caulking from the seam between the wall tile and tub, some of the caulking has adhered so tightly to the grout that portions of the grout are coming out with the caulking. Is it necessary to put grout back? I was going to simply caulk over it. Pics below.
jlmran is offline   Reply With Quote
Old 12-29-2013, 06:18 PM   #2
Rewards Points: 12,794
That vertical grout should be replaced and sealed.
More of it will need to be removed in that area so it will have something to grab on to.
To get anything to stay stuck to that area all that old caulking needs to go.
New caulking will not stuck to old.
Wipe the area down with rubbing alcohol once the old caulking is gone.
Only use silicone with a mildicide.
Fill the tub 1/2 full of water before applying the caulking. Let it dry as long as possible before draining the tub.
There's no need to have the caulking up the tiles or all over the tub like that. Only needs to fill the gap.
Old 12-29-2013, 06:33 PM   #3
Rewards Points: 506
Vertical grout replaced: every seam? How high?
Is effective grout sealer a common item at big box stores?
(I'm fairly ignorant about tile/grout)
Old 12-29-2013, 07:27 PM   #4
No, just the bottom where it's missing.
A simple grout saw will do it.
http://www.homedepot.com/p/QEP-Handh...12Q/100001353#
Yes the box will have sealer.
All that grout should be cleaned and resealed ever few years.
jlmran (12-29-2013)
Old 01-02-2014, 11:14 PM   #5
Rewards Points: 506
Update questions:
Below are photos of my finished cleaning and re-grouting, between the tiles and tub. I'm waiting for the grout to fully cure before sealing, according to the manufacturers instructions.
My question for clarification: Do I also need to apply caulking over the sealed grout at the tub/tile seam? Maybe I left too much grout at the seam, but it seems like a nice finish, and I'm not sure what the caulking will contribute, and I'm not sure if the "shape" of this new grout seam will allow for a smooth bead of caulk. Thoughts?
Old 01-04-2014, 03:14 PM   #6
Rewards Points: 3,130
I'm not a pro, and may be misunderstanding something, but I don't think the gap between the tile and tub should've been grouted at all, just caulked. Fill the tub and step in, the grout's just going to crack from the movement of the tub. Movement is also why the vertical corners are caulked instead of grouted. There's a reason you can buy caulk that matches the color of your grout.
Old 01-04-2014, 03:22 PM   #7
Rewards Points: 506
Maybe my original post wasn't clear. The original HORIZONTAL seam (along the length of the tub) had grout and caulk. While removing the old caulk, much of the grout came out with it.
So, I cleaned it all out put new grout back in the seam.
The tub sits on a concrete slab. Will it still flex enough to crack the grout when weight is added?
Old 01-04-2014, 09:57 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 204
You were supposed to caulk that joint. That's why someone caulked over the old grouted joint, grout cracks if there's movement.
Yes it will, you've already experienced that. The tub flexes, the wall moves etc.
Jaz
Old 01-04-2014, 11:05 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 776
I agree with Jaz.....
But on a more positive note.....you did a nice job of grouting.....
Hopefully Jaz will chime in...but I'm thinking you have two choices...fix it now....or....leave it until it cracks. If it was me....I would wait until it cracks.
ddawg16 is online now   Reply With Quote
Old 01-04-2014, 11:32 PM   #10
Rewards Points: 506
Well I guess the grout isn't that difficult to remove, so I'm inclined to use it as is and see how long the grout lasts. If it begins to fail, I'll scrape it out and caulk the seam. Thanks for the input.
FYI - the vertical corner seams in the shower/tub are grouted behind the caulk as well.
Caulk tile to tub seam before or after grout? Arsinek Remodeling 1 08-19-2013 08:52 PM
Tile trim...leave room for grout? sablesurfer Drywall & Plaster 3 06-12-2013 09:11 AM
Grout or caulk bathtub tile corners aigsrone Tiling, ceramics, marble 1 08-03-2012 12:18 PM
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Bonsal tile & grout caulk tube biancagrayling Tiling, ceramics, marble 2 02-22-2009 02:48 PM
