Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-11-2011, 12:20 PM   #1
Tile backsplash if have laminate with wood edge??
In my kitchen I have laminate countertops with a wood edge, even on the 4 inch backsplash. To update the look for resale, I would like to add tiles. I would like to cover the remaining drywall with tiles but I think it will look odd to have tile continue up from the partial laminate wood edge. Is there anything I can do?? Can I remove the wood portion????? Any ideas and pictures would greatly be appreciated
simiesue is offline   Reply With Quote
Old 04-11-2011, 08:26 PM   #2
Handyman
speaking of pictures...can you show us what you have?
canadaclub is offline   Reply With Quote
Old 04-12-2011, 11:01 AM   #3
So you're saying you have a 4" wood backslash on the wall now? This is odd as that item is usually the same material as the counter. If this was added after the counter, and not attached to the counter, then remove it and tile the whole wall.
If you're not sure if it's mechanically connected, you would need to find out before you attempted it's removal as it could damage the counter.
Ron
Old 04-12-2011, 12:20 PM   #4
Ron,
The 4 inch backsplash is laminate (like the counter) but it has a wood top to it. It is ugly... and I want to sell my house so I need to figure out how to make it look better. I will take a picture to show you guys..
Old 04-12-2011, 01:15 PM   #5
Ron,
Then remove it and tile the wall. How you remove it is based on how it's installed. If it's screwed up through the counter, then you'll need to loosen the counter from the cabinets and get access to the screws from below.
Take pictures of the whole counter. If it's an "L" counter against 2 walls, it will be tricky.
Ron
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 02:58 PM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 12:58 PM
tile, wood or laminate for kitchen/foyer? goldfam Flooring 10 01-28-2009 12:36 PM
