Tile Alignment - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-19-2014, 02:51 PM   #1
cia2a's Avatar
Rewards Points: 18
Tile alignment
I am now getting ready to tile shower walls. THe pan in level on all sides the walls are straight, however when I tape tiles down just to see how they align I find the side walls tiles as I go up the gap between the back wall widens. The entire 3 tiles are level next to each other and the bottom of the tile against the back wall touches the wall and there is a 1/8 gap at the top of the tile. IF I set a second level of tiles the second tile against the back wall now is 3/8 to a 1/4 away from the wall but the tiles are level across the top. What gives.
THanks everyone
cia2a is offline   Reply With Quote
Old 07-19-2014, 03:03 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,850
If I understand you correctly,(?????) it's just that your "sidewall" is not plumb.?
(Maybe your "backwall"... can't quite understand your references..... and "straight" does not mean plumb.... not sure what you mean "straight".)
I think it's pretty much a question of geometry (or else you got one of those bad batches of tile that shrink with elevation)
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 07-19-2014, 03:26 PM   #3
cia2a's Avatar
Rewards Points: 18
Yes, I mean plumb, sorry for not using the right terminology.
Old 07-19-2014, 04:13 PM   #4
DIY staff
Rewards Points: 7,174
I've tiled a bunch of tubs and showers and never once found one that was absolutely level---
I always plan on a cut tile at the tub---most times,I will screw a ledger board to the wall a little less than one tile up from the tub---when the walls are complete--I remove the ledger board and add the cuts above the tub.
Old 07-21-2014, 06:07 PM   #5
Rewards Points: 730
Since tiles have to be scribed to the wall, I'd face having to cut more tiles and plan the layout that way. At the corners, only the tiles that overlap need careful spacing.
carpdad is offline   Reply With Quote
Old 07-21-2014, 10:28 PM   #6
Carp... Agree with ya sorta... Though I do believe it is easier/worthwhile to level/plumb that shower stall when walling it, rather then cutting tile....
Just an opinion. (Although there is always some adjustment in cutting)
Best
Old 07-29-2014, 09:15 AM   #7
Rewards Points: 730
I was thinking the OP is committed to the wall he has, unless he removes all of it and start over, using the level, this time.
My bath reno also had walls that wasn't plumb and square, although not much. Correcting the wall for less tile cutting/using full tiles meant fixing the whole of 3 walls, at least. I decided to skip the fussy work. The out of plumb wasn't that bad, and it doesn't show obviously over the rows of tiles. Standard bath tub in 8' ceiling.
The Following User Says Thank You to carpdad For This Useful Post:
MTN REMODEL LLC (07-29-2014)
tile shower replacement with new tile Axhammer Remodeling 86 08-19-2013 07:22 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
