Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-09-2012, 01:10 AM   #1
This thinset sticks like mastic?
Does polymer modified portland cement thin set mortar grip tiles as good as mastic? I read that regular thin set has difficulty 'holding' the tiles to the wall.
darsunt is offline   Reply With Quote
Old 02-09-2012, 07:01 AM   #2
Super Moderator
There is more 'slide' while setting,with a thinset than a premixed mastic---some grip better than others-
Most setters will leave out the first (bottom) row of tiles and attach a temporary ledger board to give the tiles a firm starting point.
Once set the tile are more firmly attached with thinset---and there is no chance of the tiles coming loose in a wet area---bucket mastics will dissolve when exposed to water--
Old 02-11-2012, 01:30 AM   #3
Then what I read is inaccurate? I've read that thinset is so poor at grabbing tiles that some tile setters only put up 3 rows of tile at a time to prevent them from falling off. But from what you said, some thin set grabs just fine. The thin set installation I just saw, the tiles are holding on just fine without any special help.
Old 02-11-2012, 07:52 AM   #4
Super Moderator
I stick tiles to the ceiling all the time,using thinset---no problem---sliding down can be a problem on a wall--that's why the ledger---you can do an 8 foot tall wall in one shot if the bottom tile is secure and spacers or wedges are used between tiles.
I haven't used mastic in years--just thinset--some have great grab---others not so much--different surfaces (floors--walls--ceilings) might call for switching products.
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 09:27 AM
Mastic vs. Thinset Tahmeroo General Discussion 10 04-25-2011 10:49 PM
Bullnose. MAstic or Thinset. Xchair Flooring 7 03-27-2011 08:50 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Mixing Mastic and Thinset in a Tile Job smata67 Building & Construction 2 08-09-2009 11:38 PM
