-   -   This thinset sticks like mastic? (http://www.diychatroom.com/f15/thinset-sticks-like-mastic-133104/)
darsunt 02-09-2012 01:10 AM
Does polymer modified portland cement thin set mortar grip tiles as good as mastic? I read that regular thin set has difficulty 'holding' the tiles to the wall.
oh'mike 02-09-2012 07:01 AM
There is more 'slide' while setting,with a thinset than a premixed mastic---some grip better than others-
Most setters will leave out the first (bottom) row of tiles and attach a temporary ledger board to give the tiles a firm starting point.
Once set the tile are more firmly attached with thinset---and there is no chance of the tiles coming loose in a wet area---bucket mastics will dissolve when exposed to water--
darsunt 02-11-2012 01:30 AM
Then what I read is inaccurate? I've read that thinset is so poor at grabbing tiles that some tile setters only put up 3 rows of tile at a time to prevent them from falling off. But from what you said, some thin set grabs just fine. The thin set installation I just saw, the tiles are holding on just fine without any special help.
oh'mike 02-11-2012 07:52 AM
I stick tiles to the ceiling all the time,using thinset---no problem---sliding down can be a problem on a wall--that's why the ledger---you can do an 8 foot tall wall in one shot if the bottom tile is secure and spacers or wedges are used between tiles.
I haven't used mastic in years--just thinset--some have great grab---others not so much--different surfaces (floors--walls--ceilings) might call for switching products.
