Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-22-2006, 09:35 PM   #1
Thinset question
Is polymer-modified mortar (one bag) the same as standard mortar mixed with the ad-mix that comes in a jug?
Would you recommend epoxy grout for wall tile in a kitchen above a countertop and stove, or will regular sanded grout work OK as well?
billinak is offline   Reply With Quote
Old 11-24-2006, 07:52 PM   #2
Thinset question
polymer-modified mortar and ad-mix added to standard mortar are
basically the same thing. The modified morter is a little less messy
to work with in my opinion.
And I wouldn't go to the trouble of using epoxy grout unless
you have a situation where extreme protection is needed.
It is very difficult and un-forgiving to work with compared
to standard grout with a latex additive.
Hope this helps
jbob is offline   Reply With Quote
Old 11-24-2006, 10:11 PM   #3
DIY'er
Thinset question
The admix is used to increase bond as it uses the admix instead of water. Because it is in a stonger bond it may be usefull for a tub/shower surround or perhaps a tile on tile application. I dont think for the kitchen backsplash you really have to worry....A good modified thinset would be fine.
As for epoxy grout, they are, as stated by jbob, a pain in the ass to work with...with one big exception in my opinion...Spectralock. Stainproof, you never need to seal it, the look is flawless and it is surprisingly easy to use. You can even freeze what you dont use and break it out later, let it sit for a little while and then reuse. The drawback, of course, is that it is expensive. Lowes carries it.
I dont think it would be necessary for a backsplash because they just dont take much abuse...but for a surround and definetly for floors it is ideal.
Hope that helps
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
HELP! Question about Eldorado Stone EricW Building & Construction 8 10-24-2006 05:24 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
