Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-23-2012, 10:48 AM   #1
Is thinset alright as a joint compound for wallboard?
Hello, I am remodelling my bathroom and am wondering if I can use thinset as a joint compound for wallboard. The shower is all cement board, then the walls are a mix of cement board and wall board. I will be tiling roughly 4 feet up the non shower walls. I was curious if I would be alright with just mixing a bathc of thinset to fill in gaps between sheets. I have the correct tape for both wall board and cementboard. Thanks in advance for any advice.
Jerrys84 is offline   Reply With Quote
Old 09-23-2012, 09:45 PM   #2
homeprova's Avatar
It's okay to fill in the joint between the two wall boards with thinset, but you must install fiberglass joint tape over the seam. One this is complete, you must use light weight drywall mud or EZ sand 20 minute mud to adhere correctly on the first coat. Then you can either finish it with regular drywall mud or the 20 minute, doesn't matter.
homeprova is offline   Reply With Quote
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
dots in joint compound insearch Painting 2 06-01-2011 10:44 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
