These Tapcon Screws Are A Bear - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-09-2007, 07:46 PM   #1
I am just beginning my basement remodel and am having trouble with the tapcon screws. I am putting them into PT lumber for the bottom of my walls. I am following the directions, and using the provided drill bit. But I keep breaking them off when I screw them into the ground.
Any suggestions?
Thanks,
Stingray is offline   Reply With Quote
Old 04-09-2007, 07:49 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Any suggestions?
Thanks,
Try to drill deeper into the concrete, before inserting the screws and tightening.
- Build Well -
Old 04-09-2007, 07:52 PM   #3
Lehigh Valley PA
I don't know what your using to tighten them down but I found when I used my cordless drill to drive them in they would snap off pretty easily.
When I tightened them by hand to a good snug fit I had much more luck.
I also agree with Atlantic.... drill deep enough holes so they don't bottom out.
Nhrafan is offline   Reply With Quote
Old 04-09-2007, 07:59 PM   #4
Good advice as well...
- Build Well -
Old 04-09-2007, 08:34 PM   #5
Master Craftsman
Big Dave's Avatar
Make sure your not using ones that are too long. Also I will drive them in til they get tight and back them out and do it again a few times til I get it where I want it.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 04-09-2007, 08:50 PM   #6
yummy mummy's Avatar
Rewards Points: 1,016
Whenever I put the tapcons in, I would always make sure that the drill bit extended 1/2 and inch longer than the screw when I inserted it into my hammer drill.
I would always get them in perfectly flush with the pressure treated wood this way.
yummy mummy is offline   Reply With Quote
Old 04-10-2007, 09:41 AM   #7
using right length tapcon is also very important, too long will make your job too hard unnecessary...
KUIPORNG is offline   Reply With Quote
Old 04-10-2007, 09:50 AM   #8
Rewards Points: 1,088
Might want to get your shop vac and vac out all the dust in the hole before trying to drive a screw.
handy man88 is offline   Reply With Quote
Old 04-14-2007, 03:04 PM   #9
Thanks for all the help. I bought some longer drill bits and have been using the shop vac to get rid of the dust. They are going right in now. You would think the drill bit provided in the package would have done the job, well live and learn I suppose.
Thank you all!!!!
Old 04-15-2007, 10:49 PM   #10
Any suggestions?
Thanks,
Rent a quality concrete drill and purchase a bit or two. A 18 volt driver and you can do all the walls in under an hour.
You need to have the right tool for the job.....
woodmagman is offline   Reply With Quote
Old 04-16-2007, 08:40 AM   #11
Also, need to use the right 18v, the cheap ones is no good... drive one screw and battery is out...
I got Milwaukee... this guy can perform wonder....
Old 04-16-2007, 09:21 AM   #12
I have an 18V Milwaukee hammer drill and their batteries are crap. I'm itchin' to buy replacement Lithium Ion batteries for my drill, but it costs $199 for two batteries and charger. I'll buy it when I need it.
Old 04-16-2007, 10:27 AM   #13
why would you say Milwaukee batteries are crap... short life? or not enough power... it works very long lasting for me so far (after 2 months of usage)
Old 04-16-2007, 11:07 AM   #14
I am using a corded B&D hammer drill. once I started drilling deeper the problems went away. I got all the screws in quickly.
Thanks again.
Old 04-23-2007, 07:40 PM   #15
Easiest solution I have found for a fool proof method is use the tap cons with hex heads, drill your holes with a hammer drill, then use a impact wrench to install the tapcons. Bada-boom-bada-bing, fool proof, anybody can do it, no vacuum, no skills needed, the hex head versions and the impact wrench do all the work.
Mike Finley is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 10:27 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
