I am just beginning my basement remodel and am having trouble with the tapcon screws. I am putting them into PT lumber for the bottom of my walls. I am following the directions, and using the provided drill bit. But I keep breaking them off when I screw them into the ground.
I don't know what your using to tighten them down but I found when I used my cordless drill to drive them in they would snap off pretty easily.
When I tightened them by hand to a good snug fit I had much more luck.
I also agree with Atlantic.... drill deep enough holes so they don't bottom out.:thumbsup:
Make sure your not using ones that are too long. Also I will drive them in til they get tight and back them out and do it again a few times til I get it where I want it.
Whenever I put the tapcons in, I would always make sure that the drill bit extended 1/2 and inch longer than the screw when I inserted it into my hammer drill.
I would always get them in perfectly flush with the pressure treated wood this way.
Thanks for all the help. I bought some longer drill bits and have been using the shop vac to get rid of the dust. They are going right in now. You would think the drill bit provided in the package would have done the job, well live and learn I suppose.
Rent a quality concrete drill and purchase a bit or two. A 18 volt driver and you can do all the walls in under an hour.
You need to have the right tool for the job.....
I have an 18V Milwaukee hammer drill and their batteries are crap. I'm itchin' to buy replacement Lithium Ion batteries for my drill, but it costs $199 for two batteries and charger. I'll buy it when I need it.
why would you say Milwaukee batteries are crap... short life? or not enough power... it works very long lasting for me so far (after 2 months of usage)
Easiest solution I have found for a fool proof method is use the tap cons with hex heads, drill your holes with a hammer drill, then use a impact wrench to install the tapcons. Bada-boom-bada-bing, fool proof, anybody can do it, no vacuum, no skills needed, the hex head versions and the impact wrench do all the work.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
